clutch pedal stays DOWN
can any body help....I was driving the other day when my clutch pedal went all the way to the floor..so i said maybe i need fluid..so i filled ur up and got home looked at the resevor again it was EMPTY...me and my dad relaced the both cylinders, but no pressure builds up in the lines..so there for the pedal stays to the floor aany1 have info...? :help: :help:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">sounds like you need a new slave cyclinder, so while you change that, you may as well change the master cyclinder </TD></TR></TABLE>
he already did that.
bleed your clutch again. Use a vacuum bleeder if the traditional method doesn't work for you.
he already did that.bleed your clutch again. Use a vacuum bleeder if the traditional method doesn't work for you.
I just replaced my master cylinder last Wednesday and ya...bleeding the system is a bitch. Replaced the cylinder in about 30 minutes...took about another 30 minutes just to bleed it...pump your slave cylinder back towards the reservior...that's where my problem was...it was a LOT of air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn »</TD></TR><TR><TD CLASS="quote">same exact thing happened to me...
open bleeder, push in pedal, get person on other side to close it.. repeat until you see new fluid/no bubbles..</TD></TR></TABLE>wrong buddie you pump the pedal then hold it in and then you open the bleeder. repeat until you have no bubbles.
707EF8
Jul 29, 2006 08:32 PM
