broke valve cover studs need help
I broke 3 of the inner valve cover studs last night, the studs are the ones that also are used for the spark plug wire cover.Befor a take it back apart to fix it does anybody know wher i can get the studs today.
Acura and/or Honda dealership should have them. Those things are SO easy to break -- I've done it many times. Be sure not to exceed their torque spec, and you should be fine, once you replace the broken ones.
