Car smells like gas when I floor it.
Old Feb 10, 2002 | 07:18 PM
AlphaKennyWun's Avatar
Default Car smells like gas when I floor it.
Although im not going to have the car running without a standalone for much longer, I always wanted to know why my car which has a BBK 225lph, 12:1 FMU, stock injectors t3/t4 turbo smells like gas after applying 3/4 pressure to peddle or more. Am I flooding the engine or what? tough to tell without a fuel pressure gauge or egt etc.
Old Feb 10, 2002 | 07:23 PM
maxim's Avatar
Default Re: Car smells like gas when I floor it. (SO3Burner)
Do you at least have an A/F gauge? Do you notice any black smoke coming out the back when you floor it? would say the 12:1 is making you run rich. If you had a fuel controller you could lean it out, but don't worry about that since you wll have standalone.
Old Feb 10, 2002 | 07:28 PM
Default Re: Car smells like gas when I floor it. (maxim)
nope. Dont have none of that. No black smoke either. I believe i am running rich. Im not worried. I just wanted to know if by running rich "I" could smell unburnt gas emitting from my motor.
Old Feb 10, 2002 | 07:36 PM
Ri5e's Avatar
You probably leaking oil somewhere around the FMU. I'm guessing that the hose clamps are tightened and the fuel pressure forces itself through.
Old Feb 10, 2002 | 11:26 PM
DLB1994's Avatar
Default Re: Car smells like gas when I floor it. (BG Boost)
You probably leaking gas somewhere around the FMU it happin to me a few times
Old Feb 11, 2002 | 06:13 AM
dbman96's Avatar
New User
You are smelling that rich unburnt fuel because at 3/4 throttle your wastegate is starting to open and putting that rich exhaust right in front of you. If it was all going out the tailpipe you probably wouldn't notice, but air from underhood ends up going in your cabin vents.
Fastwhip
Aug 27, 2007 11:45 AM
93IntegraRacer
Feb 11, 2004 09:34 AM
jspek29
Jun 10, 2003 05:39 PM
SoNNyBoY9o9
Nov 3, 2002 01:50 PM
Guitarzann
Jan 21, 2002 02:59 PM
