Need Help with Oil Leaking in the Front
I got a 93 Accord Ex Coupe...I keep having oil leaks in the front..If you were seating in the driver seat it would be leaking on ur left front tire, but if you were look at the engine it would be ur front right tire...the symptoms that shows up are burning oil odor that would flow in through the vents or if you open the window it would flow straight to you..It would kind of smell like burning rubber too...I remeber seeing a solution which stated that it could be the oil pressure Switch/Sender...But do 93 accord coupe Ex have those in them...It als stated that it's just above the oil filter..But as i went under my car, i couldn't find the oil pressure switch...Could that be the solution to this problem...Also please tell me if my car even haves it..cause my cuz stated that the 90 to 93 accords dont have the Oil pressure Switch/Sender..if it does where could it be located..???
PS
I got a F22A6 Engine
Modified by WaZZuP at 8:37 AM 6/13/2005
PS
Honda knowledge
Jan 7, 2016 04:45 PM
MC Slide Hammer
Jul 1, 2012 09:08 PM
