block warpage with rad leak?
Old Feb 10, 2002 | 06:59 PM
mr tl's Avatar
Default block warpage with rad leak?
about 10K miles ago my rad started leaking on the upper tank and upper hose. the rad was replaced under warranty.
im wondering if it was possible for air to get into the system, and possibly causing uneven cooling for the block - leading to warpage. ( i was still driving the car, and filling up the over flow bottle every few days)
the car is perfect. but im just curious about side effects. or am i just being paranoid
thanks
Old Feb 11, 2002 | 08:20 AM
rtype11's Avatar
Default Re: block warpage with rad leak? (mr tl)
if your rad problem lead to extremely high coolant temps then you may have damaged some bearings, but you would have had to have car in the red zone for that. stop smoking the ganja and you wont be so paranoid.
Old Feb 11, 2002 | 01:07 PM
bob01721's Avatar
I wouldn't worry about that. The place that replaced the rad would have bled the cooling system of air.
If air DOES get trapped, it'll find the highest point in the system, up by the bleeder bolts -- and the temp sensor. If there were air in the system, your idle would be "hunting" every time that bubble bounced around the sensor.
As long as your temp gauge isn't showing anything out of the ordinary, I wouldn't worry.
jonyi27
Dec 27, 2013 05:17 PM
screaminj
Honda Fit
Sep 30, 2009 09:13 PM
732xghost
Aug 23, 2009 08:48 PM
98GSRrdr
May 9, 2007 11:16 AM
1.8T_EG
Oct 28, 2002 04:17 PM
