1998 ITR for $11,000?? What do you think is wrong, if anything??
Found this ad while looking for my (hopefully) next car. Price seems a little low, I did not do a Carfax since I am not going to purchase it now and didn't want to spend the $$. I am going to call the dealer, just out of curiosity tomorrow.
http://www.cars.com/go/search/...ional
Air Conditioning, Tilt Wheel, AM/FM Stereo, Single Compact Disc, Dual Front Air Bags, ABS (4-Wheel), Alloy Wheels, Maintenance-Free Battery, 90-Amp Alternator, Electronic Ignition System W/Knock Sensor, Independent Double Wishbone Front Suspension W/Coil Springs, Stabilizer Bar, Front/Rear Gas Pressurized Shock Absorbers W/Progressive Valve, Pwr-Assisted Dual Diagonal 4-Wheel Disc Brakes (Vented Front), 4-Wheel Anti-Lock Brake System, Galvanized Body Panels, 13.2 Gallon Fuel Tank, 3-Coat, 3-Bake Paint, Pwr Moonroof, Body-Colored Front/Rear 5-Mph Bumpers, Rear Spoiler W/Integral Brakelight, Body-Colored Protective Body-Side Moldings, Body-Colored Door Handles, Projector Beam Headlights (Low Beams), Body-Colored Dual Pwr-Operated Door Mirrors, Intermittent Front Wipers W/Mist, Rear Window Wiper/Washer, Passenger-Side Walk-In Seat, 50/50 Fold-Down Rear Seatbacks W/Rear Seat Divider, Rear Seat Headrests, Center Console W/Armrest, Pwr Door Locks, Pwr Windows, Map Light, Cruise Control, Rear Window Defroster W/Timer, Remote Fuel Filler Door Release, Pwr Antenna, 3-Point Outboard Front/Rear Seat Belts, Front/Rear Crumple Zones, Side-Impact Door Beams, Side-Intrusion Hip Pads
this doesnt look like ITR center console .. i though ITR got CF trimming? correct me if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">
ITR's had the CF trim in 00 and 01, IIRC. And there doesn't appear to be a sunroof/moonroof in the pics. Probably a generic listing.
</TD></TR></TABLE>ITR's had the CF trim in 00 and 01, IIRC. And there doesn't appear to be a sunroof/moonroof in the pics. Probably a generic listing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">but whats up with "pwr moonroof" and "body-side moldings" ?
Generic listing?? The pics show neither.
</TD></TR></TABLE>Generic listing?? The pics show neither.
Looks like a steal. When I was looking for a itr last year I found one on autotrader that was only $11,000. When I called the dealership they didn't even know what they had. I tried to buy it but someone else got it first. The only reason I didn't buy it was because it was on the other side of the country and I didn't give them a down payment fast enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">Air Conditioning, Tilt Wheel, AM/FM Stereo, Single Compact Disc, Dual Front Air Bags, ABS (4-Wheel), Alloy Wheels, Maintenance-Free Battery, 90-Amp Alternator, Electronic Ignition System W/Knock Sensor, Independent Double Wishbone Front Suspension W/Coil Springs, Stabilizer Bar, Front/Rear Gas Pressurized Shock Absorbers W/Progressive Valve, Pwr-Assisted Dual Diagonal 4-Wheel Disc Brakes (Vented Front), 4-Wheel Anti-Lock Brake System, Galvanized Body Panels, 13.2 Gallon Fuel Tank, 3-Coat, 3-Bake Paint, Pwr Moonroof, Body-Colored Front/Rear 5-Mph Bumpers, Rear Spoiler W/Integral Brakelight, Body-Colored Protective Body-Side Moldings, Body-Colored Door Handles, Projector Beam Headlights (Low Beams), Body-Colored Dual Pwr-Operated Door Mirrors, Intermittent Front Wipers W/Mist, Rear Window Wiper/Washer, Passenger-Side Walk-In Seat, 50/50 Fold-Down Rear Seatbacks W/Rear Seat Divider, Rear Seat Headrests, Center Console W/Armrest, Pwr Door Locks, Pwr Windows, Map Light, Cruise Control, Rear Window Defroster W/Timer, Remote Fuel Filler Door Release, Pwr Antenna, 3-Point Outboard Front/Rear Seat Belts, Front/Rear Crumple Zones, Side-Impact Door Beams, Side-Intrusion Hip Pads
OMG you found two small details that show only one thing, the dealer doesnt know what they're talking about, and neither do you! Those 3 small little details can be clairified by looking at the pics (roof/doors), and the misinformation you're talking about is posted like 5,000,000 times(trim).
You could run the VIN if you were actually trying to play a good detective, since its the last hard proven method to find out if it is real, or if you actually knew what you were talking about you'd know that JH4DC231 means it is in fact an ITR.
For the people that actually know stuff/care the title came up as an ITR (as stated) has had at least 1 owner from Texas, and the title came back clean.
OMG you found two small details that show only one thing, the dealer doesnt know what they're talking about, and neither do you! Those 3 small little details can be clairified by looking at the pics (roof/doors), and the misinformation you're talking about is posted like 5,000,000 times(trim). You could run the VIN if you were actually trying to play a good detective, since its the last hard proven method to find out if it is real, or if you actually knew what you were talking about you'd know that JH4DC231 means it is in fact an ITR.
here you go.
EDIT: its a lot of trash that i just posted but hopefully it helps you out some.
Since its establishment as an independent company in 1986, CARFAX has collected the largest vehicle history database in North America. This database currently includes over 3 billion records from thousands of public and private sources.
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
Heading Graphic
CARFAX Buyback Guarantee Good News -- Vehicle qualifies for the CARFAX Buyback Guarantee!
No severe problems (major accidents, fire, flood damage, major odometer problems or lemon history) were ever reported by a Department of Motor Vehicles (DMV) for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). If you find that any of these severe problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back.
You must register at http://www.CARFAX.com to activate this free guarantee!
CARFAX Talking CarTM
The story of this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507) according to our interpretation of the information reported to CARFAX:
Blue Arrow This hatchback has had 1 owner in Texas. The first title for this hatchback was reported to CARFAX by a Texas DMV in 1998.
Blue Arrow It has had no minor or moderate accidents reported to CARFAX.
Blue Arrow It has had no DMV-reported total loss events, like a major accident, fire or flood.
Blue Arrow It has not been reported by a DMV as having an Exceeds Mechanical Limits or Not Actual Mileage title.
Blue Arrow It has a consistent mileage history with no indication of an odometer rollback. It was driven an average of 8,935 miles per year, which is lower than the industry average of 15,000. The last odometer reading, reported on 05/31/2005, was 64,483 miles.
Blue Arrow It was not reported by a DMV as a Manufacturer Buyback (LEMON).
Blue Arrow Its basic warranty has expired. You may want to discuss an extended warranty with your dealer.
Blue Arrow Go to the Detailed Vehicle History for the complete history and a glossary of terms.
Click here to find out more!
Report Summary
1. ACCIDENT CHECK
Total Loss Check No Severe Accidents Reported by a DMV - Buyback Guarantee!
Other Accident Indicators No Accident Indicators Reported
2. MILEAGE ACCURACY CHECK
Truth-In-Mileage Check No Odometer Problems Reported by a DMV - Buyback Guarantee!
Odometer Rollback Check No Potential Odometer Rollback Found
Mileage Consistency Check No Inconsistent Odometer Reading Found
3. LEMON CHECK®
No Mfr. Buyback Reported by a DMV - Buyback Guarantee!
4. OWNERSHIP CHECK
Number of Owners 1 Estimated Owner(s)
Type of Owners Checked 8 Types of Vehicle Registrations
5. RECALL CHECK
ACURA Does Not Report Recalls to CARFAX
6. WARRANTY CHECK
No Coverage Remaining on Basic Warranty. Interested in an Extended Warranty?
DETAILED VEHICLE HISTORY 7 HISTORY RECORDS REPORTED
Tell us what you know about this vehicle
Heading Graphic
Year/Make/Model: 1998 ACURA INTEGRA TYPE-R
Body Style: HATCHBACK 2 DR
Engine: 1.8L L4 PFI DOHC VTEC
Fuel: GASOLINE
Driveline: FRONT WHEEL DRIVE
Manufactured in: JAPAN
Safety Equipment: 4 wheel ABS, Dual front air bags/active (manual) belts
Standard Equipment: Power Windows, Power Steering, Air Conditioning Optional, AM / FM CD, Power Brakes, Tilt Wheel, 6-digit Odometer
CARFAX Hot Listings
Find great cars just listed in your area — for FREE.
View more listings for this type of vehicle
1998 ACURA INTEGRA RS
Body Style: Hatchback 2 DR
Engine Type: 1.8L L4 PFI DOHC 16V
VIN: JH4DC4348WS013945 [ Free CARFAX Report ] Z-Whizz Auto Repair & Sales
Distance: 13.04 mi
Contact Dealer | Web Site
1998 ACURA INTEGRA GS
VIN: JH4DC4465WS008105 [ Free CARFAX Report ] Bank Auto Resales
Distance: 22.28 mi
1999 ACURA INTEGRA GS-R
Engine Type: 1.8L L4 PFI DOHC VTEC
VIN: JH4DC2397XS002632 [ Free CARFAX Report ] Auto Authority
Distance: 20.33 mi
Let us do the work!
Be the first to know about 1998 ACURA INTEGRA vehicles just listed for sale in your area.
Email Address:
Heading Graphic
FREE to you from CARFAX. Additional information to help you make the right decision when buying or selling a used car or truck.
Blue Arrow
How safe and reliable is this 1998 ACURA INTEGRA TYPE-R?
Find out with the CARFAX Safety & Reliability Report.
Blue Arrow
What are other CARFAX customers saying about this 1998 ACURA INTEGRA TYPE-R?
Share what you know about this vehicle - Add a CARFAX Customer Rating & Comment.
Heading Graphic
Total Loss Check:
GOOD NEWS! No severe damage events were ever reported by a DMV for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). If you find that any of the following severe problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back. You must register to activate this free guarantee!
Salvage Title Loss Due To Fire Title
Junk Title Flood Damage Title
Rebuilt/Reconstructed Title Hail Damage Title
Dismantled Title Canadian Total Loss
Other Accident Indicators:
This 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507) had no accident indicators reported to CARFAX from its sources. This section checks for accidents and/or related damage reported from many public and private sources. Not all accidents are reported to CARFAX. A vehicle inspection completed by your dealer or professional mechanic is recommended.
No Salvage Auction Record Reported No Crash Test Vehicle Record Reported
No Fire Damage Record Reported No Airbag Deployment Record Reported
No Frame Damage Record Reported No Damage Disclosure Record Reported
No Police Accident Record Reported No Collision Repair Facility Record Reported
CARFAX depends on public and private sources for its accident data. Each one of these sources has different processing times. CARFAX can only report what is in our database on 13.Jun.2005 00:41:52. New data will result in a change to this report.
Not all accidents are reported to the Police. Tell us if you know of other fender benders, accidents or damage.
Register FREE Guarantee | CARFAX Help Center
Heading Graphic
Truth-In-Mileage Check:
GOOD NEWS! No major odometer problems were ever reported by a DMV under the Truth-In-Mileage Act for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). If you find that any of the following odometer problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back. You must register to activate this free guarantee!
Not Actual Mileage Title - issued by DMV when the owner discloses mileage fraud or a broken odometer.
Exceeds Mechanical Limits Title - issued by DMV when the owner discloses an odometer rollover.
Odometer Rollback Check:
CARFAX found no odometer rollbacks for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). Rollbacks reported in this section originate from readings collected by a DMV or other verifiable source.
Mileage Consistency Check:
CARFAX found no inconsistent odometer readings in the mileage history of this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507).
Date: Mileage:
04/18/1998 6
03/13/2000 30,618
08/01/2001 39,559
05/31/2005 64,483
Average miles driven per year 8,935 CARFAX AdvisorTM Compare this vehicle's average annual mileage to the industry average of 15,000 miles per year. Use this comparison to determine how this vehicle was driven.
Do you know this vehicle's current mileage? Tell us and help protect others from mileage fraud.
Heading Graphic
GOOD NEWS! No manufacturer buyback was ever reported by a DMV for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). If you find that a manufacturer buyback was reported by a DMV and not included in this report, CARFAX will buy this vehicle back. You must register to activate this free guarantee!
Heading Graphic
Ownership History:
CARFAX estimates that this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507) had 1 owner(s). CARFAX analyzed this vehicle's title history and other supporting events to identify potential ownership transfers. In compliance with the U.S. privacy laws, CARFAX does not collect or report owner names or addresses.
Estimated Owners: Date: Location:
1st owner 04/18/1998 Texas
CARFAX AdvisorTM
The cost of ownership varies by vehicle. Go to Edmunds.com to check the recommended service schedule and estimated costs for this vehicle.
Types of Owners:
This 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507) was originally registered as a Personal Vehicle.
Personal Use Registration Reported No Fleet Registration Reported
No Lease Registration Reported No Commercial Registration Reported
No Rental Registration Reported No Non-Profit Registration Reported
No Taxi Registration Reported No Built to Non U.S. Standards Record Reported
Do you have information about how this vehicle was used or driven? Tell us what you know.
Heading Graphic
ACURA does not report recall information for specific vehicles to CARFAX.
Go to the CARFAX SAFETY & RELIABILITY REPORT for recalls issued by the National Highway Traffic Safety Administration for the 1998 ACURA INTEGRA TYPE-R. You can also contact an authorized dealership or ACURA at 1-800-999-1009 to find out if this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507) still has recalls that require repair.
Heading Graphic
For your convenience, CARFAX has estimated the remaining original manufacturer warranty coverage based on information reported to us on this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507). Please confirm remaining factory warranty and extended warranty options with your dealer. Interested in an extended warranty?
Estimated start date of warranty: 03/15/1998
Last reading reported on 05/31/2005: 64,483 miles Recalculate with current mileage
Today's Date: June 13, 2005
Type of Coverage: Original Warranty: Estimated Remaining Coverage:
Basic 48 months or 50,000 miles Coverage expired
Drivetrain 48 months or 50,000 miles Coverage expired
Emissions 24 months or 24,000 miles Coverage expired
Corrosion 60 months or unlimited mileage Coverage expired
Transferable Transferable at no cost Same
Roadside Assistance 48 months or 50,000 miles Coverage expired
Safety Belt & Inflatable Restraint No data reported to CARFAX
Specific Components 96 months or 80,000 miles 10 months or 15,517 miles
Notes: Manufacturer covers emissions components under basic warranty. Emissions coverage may vary by state. Refer to owners manual for specific details. Roadside assistance covered for 4 years or 50,000 miles. Warranty transferable at no cost to subsequent owners.
CARFAX Warranty Check provides an estimate of this vehicle's remaining warranty coverage. It does not take into account some vehicle history events. For example, major accidents resulting in Salvage or Junk titles that may void the original manufacturer warranty or ownership transfers that may decrease warranty coverage. This warranty information is only valid for vehicles manufactured for sale in the US. Complete warranty coverage information is available for this vehicle at the ACURA web site.
Heading Graphic
CARFAX searched more than 3 billion records from over 5,300 sources and found 7 record(s) for this 1998 ACURA INTEGRA TYPE-R (JH4DC2313WS002507).
Date:
Mileage Reading:
Source:
General Comments:
03/15/1998 Texas
Motor Vehicle Dept.
Houston, TX
Registered as
personal vehicle
04/18/1998 6 Texas
Motor Vehicle Dept.
Houston, TX
Title #10120135890104732
Registration issued or renewed
Title or registration issued
First owner reported
03/13/2000 30,618 Texas
Inspection Station
Cypress, TX
Passed emissions inspection
08/01/2001 39,559 Texas
Inspection Station
Cypress, TX
03/01/2002 Texas
Motor Vehicle Dept.
Houston, TX
Passed safety inspection
03/19/2003 Texas
Motor Vehicle Dept.
Pflugerville, TX
Title issued or updated
05/31/2005 64,483 Dealer Inventory
Round Rock, TX
Vehicle offered for sale
Heading Graphic
Report Summary
1. ACCIDENT CHECK
3. LEMON CHECK®
4. OWNERSHIP CHECK
5. RECALL CHECK
6. WARRANTY CHECK
Heading Graphic
Fuel: GASOLINE
CARFAX Hot Listings
Distance: 13.04 mi
Distance: 22.28 mi
Distance: 20.33 mi
Let us do the work!
Email Address:
Heading Graphic
Blue Arrow
Blue Arrow
Heading Graphic
Total Loss Check:
Heading Graphic
Date: Mileage:
04/18/1998 6
03/13/2000 30,618
08/01/2001 39,559
05/31/2005 64,483
Heading Graphic
Heading Graphic
Ownership History:
CARFAX AdvisorTM
Types of Owners:
Heading Graphic
Heading Graphic
Heading Graphic
Date:
Mileage Reading:
Source:
General Comments:
03/15/1998 Texas
Motor Vehicle Dept.
Houston, TX
Registered as
personal vehicle
04/18/1998 6 Texas
Motor Vehicle Dept.
Houston, TX
Inspection Station
Cypress, TX
Inspection Station
Cypress, TX
03/01/2002 Texas
Motor Vehicle Dept.
Houston, TX
03/19/2003 Texas
Motor Vehicle Dept.
Pflugerville, TX
Round Rock, TX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">
Guys, we really need to lighten up !!! He made a mistake, and I didn't care to run a Carfax and spend money on a car that I wasn't going to buy. Honestly I did not previously know about the VIN number, and what digits to look for to determine authenticity. But now I do, and am thankful for it. All I really wanted to know was why the price seemed to be so low, at least it looked low to me.
As far as the trim goes, maybe Y2K_S2K didn't know about the 97's and 98's. Maybe he is only familiar with the latest editions. I really don't see a need to jump like that.
</TD></TR></TABLE>Guys, we really need to lighten up !!! He made a mistake, and I didn't care to run a Carfax and spend money on a car that I wasn't going to buy. Honestly I did not previously know about the VIN number, and what digits to look for to determine authenticity. But now I do, and am thankful for it. All I really wanted to know was why the price seemed to be so low, at least it looked low to me.
Its not cool when people go posting misinformation though, thats where people get all the misconceptions and then someone goes and says the same things off what they heard, all I did was correct him.
Either way, Carfax (though should be trusted as lightly as the information in these forums) came up clean, the car looks (from the small pictures) to be clean and the mileage is all accurate. Unless you inspect the car and find major repairs that were never reported (possibility) it would still be a killer deal for the car and the mileage. Until a closer look is done in person its hard to say otherwise.
well, it says it has cruise control, too, which type-r's don't have, and you can clearly see the cruise control block-off plug on the left of the steering wheel. pretty sure it's an R. it's just a mis-listing. kinda hard to believe that the used car-lot isn't a honda guru, but maybe this guy just hasn't brushed up on his knowlegde lately
but did the 98s have that shift ****? i thought only 97s had that? i'm probably wrong, just thought i'd ask...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">I thought the 97 andf 98 Rs had "ACURA" on the steering wheel.. or what it just the 97s ???</TD></TR></TABLE>
Looks like just the 97's, D noticed that a couple weeks ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">but did the 98s have that shift ****? i thought only 97s had that? i'm probably wrong, just thought i'd ask...</TD></TR></TABLE>
Yup!
Yup!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">Its not cool when people go posting misinformation though, thats where people get all the misconceptions and then someone goes and says the same things off what they heard, all I did was correct him.
The dealer obviously views it as just another integra which is a plus to anyone who wants to buy it.
Carfax should be taken very lightly; I have to point out 2 things with my car to people since they don't show up on carfax even though both were reported thru insurance and police...
</TD></TR></TABLE>The dealer obviously views it as just another integra which is a plus to anyone who wants to buy it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash »</TD></TR><TR><TD CLASS="quote">
Carfax should be taken very lightly; I have to point out 2 things with my car to people since they don't show up on carfax even though both were reported thru insurance and police...</TD></TR></TABLE>
good man
but if the carfax IS right...this is an awesome find
good man
The side moldings are stuck on with double stick around the fender wells and doors. Nothing you cant remove with a little time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmasonGSR »</TD></TR><TR><TD CLASS="quote">ahhhh, its sold already....booooo. </TD></TR></TABLE>
of course it is.. it was a really good deal..
Gennady
Sep 20, 2002 12:28 PM
98itR484
Mar 31, 2002 11:42 AM
