What kind of clutch cable should I use for b16a swap?
I am curious what cable should I use for the b16a swap into the crx. Should it be the 1992-1993 Gsr model, or just the regular 1990-93 Integra Ls.. ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Any Teg clutch cable will work. </TD></TR></TABLE> I think he means 90-93 Teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdude »</TD></TR><TR><TD CLASS="quote">yeah, the stock cable is too tight... A friend suggested to cut it, but it's still too tight... </TD></TR></TABLE>
What do you mean by 'to tight'? I have never had a problem adjusting mine properly. Do you by chance mean that you cannot get it into the bracket on the transmission? If this is what you mean, you cannot get it in the bracket with the bracket bolted to the transmission. You MUST unbolt the bracket, slide the cable into the bracket, attach the end of the cable to the clutch lever, and then bolt the bracket to the transmission again. But once you do all this, the stock cable works fine.
use a 90-93 integra and put a hose clamp over the bushing on the end and tighten it down
https://honda-tech.com/zerothread?id=1151217
iridebiketrials
Jul 20, 2004 02:48 PM
TheHatchHog
Apr 30, 2003 11:28 PM
