swapping key locks (ignition and door)
Old Jun 12, 2005 | 06:22 PM
dxhatch93's Avatar
Default swapping key locks (ignition and door)
hey guys, my car got totaled and i found another civic shell to switch everything over to. on the shell, the ignition key is different from the doors locks. is there a way i can switch my door locks and the part where i stick the key into the ignition over onto the new shell? the shell is a 92 dx and my car is a 93 dx if that helps.
Old Jun 12, 2005 | 06:27 PM
DumpedSi's Avatar
Default Re: swapping key locks (dxhatch93)
heres a better idea.. If you have a key to the door locks on the new shell.. removed the ignition and taken it and your door lock key into a locksmith and they can repin that lock to fit your door lock key.. Total cost shouldnt be more than 10 bucks.. Save you some time and you can sell the ignition lock set from the other car
Old Jun 12, 2005 | 06:41 PM
Built Beast's Avatar
Default Re: swapping key locks (Slammed Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si &raquo;</TD></TR><TR><TD CLASS="quote">heres a better idea.. If you have a key to the door locks on the new shell.. removed the ignition and taken it and your door lock key into a locksmith and they can repin that lock to fit your door lock key.. Total cost shouldnt be more than 10 bucks.. Save you some time and you can sell the ignition lock set from the other car</TD></TR></TABLE>
I would recommend the same. It is a lot less trouble. Up to you though.
Old Jun 12, 2005 | 07:16 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: swapping key locks (Built Beast)
a lot less trouble trust me
Old Jun 12, 2005 | 09:25 PM
dxhatch93's Avatar
Default Re: swapping key locks (street dreams)
is it easy to take out the part where u stick the key into?
Old Jun 12, 2005 | 09:29 PM
_Cyclone_'s Avatar
The ignition cylinder is alot easier to remove than the door lock cylinders. Just make sure you have the key handy, or you won't be taking it out - you'll find out why.
Old Jun 12, 2005 | 09:44 PM
94hatchling's Avatar
its actually not difficult at all, just takes a little time. but i've also done this a few times, so it makes it easier. either way, get it repinned or swap over. either can be done.
Ej1Shayne
Mar 18, 2014 05:04 AM
InvaderJim
May 1, 2009 07:54 AM
pr0j3xt01v1c
Honda Civic (2001 - 2005)
Aug 1, 2008 02:59 PM
shutupnsk8
Oct 18, 2005 08:39 PM
oes
Dec 9, 2003 06:38 AM
