Burning clutch smell...I'm kind of worried...
Old Jun 12, 2005 | 06:10 PM
neocrynym's Avatar
Default Burning clutch smell...I'm kind of worried...
FYI: I already searched and found some related info, but nothing really what I was looking for.
My hatch has a stock d16z6 engine/tranny in it that was overhauled about 1 year ago. The motor has about 140k on it, so I had a heavy tune-up done to it. The tranny also has a new clutch with probably less than 10k on it. I was away at school this past year, so the car did not get driven much (probably once every 3 weeks). I am now home for the summer and drive the car every day quite a bit. Also, oil has been recently changed (always using Mobil 1) and tranny fluid was recently changed to GM Synchromesh. There's the background, here's the problem:
A few weeks ago I started noticing a very slight burning clutch smell coming from the car. It never did this before, only does it now. I don't think it's due to bad driving. I'm good at driving manual...quick shifts, tranny has never grinded any gear, and the Synchromesh makes it shift like freakin' butter. However, this burning clutch smell usually starts happening after the car is at full operating temp. and shifting normally between gears. I do not drive the car hard ever when just driving around town, but there's always a lingering clutch smell after shifting when the engine's hot (especially going thru 3rd/4th/5th gears). It's not an overwhelming smell, but it's there, and it worries me. I am worried maybe my tranny has a fluid leak, and this lack of fluid is causing more friction, etc. There are NO spots under my car when I start it every morning, though. Also, I realize tranny fluid/clutch smell may not be related directly. Finally, I don't think the clutch pedal needs to be adjusted because this only started happening very recently and I hadn't altered the car b4 this started. PLEASE HELP!!!
Anyone have this problem? Why does my car smell like clutch when just driving grandma-style around town every day. Oh, and the smell usually lasts about 5 seconds and goes away if I stay in one gear while cruising. THANKS FOR THE HELP, and sorry this was so long
Old Jun 12, 2005 | 07:29 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Burning clutch smell...I'm kind of worried... (neocrynym)
i think its the rear main seal going out and thats why u are starting to smell the clutch
Old Jun 13, 2005 | 12:01 PM
neocrynym's Avatar
Default Re: Burning clutch smell...I'm kind of worried... (street dreams)
Ughhhh...I was afraid someone would bring the rear main seal into the picture. What a bitch to change and fortune to spend having it done otherwise Anyone else have a similar problem...any other ideas?
Old Jun 13, 2005 | 12:08 PM
05em2's Avatar
yup that's what i was gonna saw...seal leaking, cost only 5$ and about 2 hours work or 1 if your good/lucky....take it as a time to inspect your brakes and control arms and suspension components etc heheh...ooooooorRRR...your clutch is really done?
Old Jun 16, 2005 | 03:18 PM
b18bciviccx's Avatar
1-2 hours for a rear main seal. Are you crazy? I know of nobody that can remove the trannny, clutch, flywheel, and then replace the rear main seal, then put the whole thing back together in less that 2 hours. I think you need to learn what a rear main seal is.
Old Jun 16, 2005 | 03:45 PM
itr-00-436's Avatar
Default Re: (b18bciviccx)
Old Jun 16, 2005 | 06:59 PM
neocrynym's Avatar
Default Re: (itr-00-436)
Haha, owned. Yeah, it's looking more and more like the rear main seal I'm gonna bring it in to my mechanic next week for his thoughts then if he thinks the same I'll fix it myself. It sounds like a pain in the *** to do, and I'd love to pay him to do it, but that won't get me any knowledge and it'll just drain my pockets $$
Any tips from anyone who's done this to someone who will prolly be attempting this for the first time? thanks.
BlueStar
Jan 15, 2009 01:50 PM
futurefastguy
Oct 13, 2006 10:32 AM
chemical
Feb 10, 2005 09:35 AM
Ditdogs
Apr 4, 2004 07:44 PM
J-Brooks
Dec 17, 2002 10:23 AM
