Honda CL 100 ignition questions
Old Jun 12, 2005 | 05:47 PM
gsc's Avatar
gsc
Default Honda CL 100 ignition questions
I've purchased a 1971 CL 100 that is not running. Getting no spark. Hoping to find answers to some ignition questions.
1. Does this motor need the battery connected to generate a spark..?
2. If not, what is the most likely problem..plugs, points, condensor, regulator..?
If anyone has knowledge of ignitions on these early 70s 4-strokes any information would be greatly appreceated.
I have a 2-stroke Yamaha GT 80 that doesn't need the battery to run. Has a magneto.
Thanks
Old Mar 9, 2020 | 05:37 PM
ChristinaAspa's Avatar
Default Re: Honda CL 100 ignition questions
This is exactly the issue I am having. We’re you able to figure out what was wrong? I know this post is old, but here’s hoping...
Old Apr 26, 2020 | 05:47 AM
trialsrc's Avatar
Yes does need a good battery. Points are probably dirty. Sand with very fine emory cloth. Then spray with carb cleaner. Then drag piece of stiff paper between them while there closed. The paper is the final cleaning procedure.
Old May 1, 2020 | 05:26 PM
leanman82's Avatar
wow 15 years later and helpful af, you deserve a medal sir
copper2290
Honda Ruckus and Scooters
Jul 11, 2017 10:43 AM
Hanmin
Mar 31, 2009 07:11 AM
B18ceed
Mar 18, 2006 04:41 PM
400whp
Mar 23, 2004 07:26 PM
