Skunk 2 Camber kit differences
What is the difference between all the SKunk 2 Camber kits?? on lyke ebay i see lyke 3 different types of camber kits from skunk 2 ... i dun get it which wuns the best? wut does it look lyke.. nd wut should be lyke required to install skunk 2s? i mean lyke i heard some bad things bout their nuts not locking correctly or staying in place or the grade of the bolts not strong enough.... thanks.. help appreciated.
i have had them on 2 cars a civic and my new gsr...for the front they rock! easy to install..its just the upper control arm you pop your old one out and new one in and bam..i think it took 30 min...on gsr..and alignment shops love them because they are easy to get to and they adjust alot both ways so it make their job easier..i would not run any other on the front..for the back ingalls is the way to go,,.,,hope this helps...
Markb16a
Suspension & Brakes
Mar 1, 2007 12:33 PM
