Tack welding aluminum
Can aluminum be tack welded with a wire feed welder or a stick welder? I just want to hold together some intercooler piping enough to take it out and have someone weld it up for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr »</TD></TR><TR><TD CLASS="quote">If your mig is set up for alum yes you can do that. </TD></TR></TABLE>
Will it work with no gas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">What about a stick welder with an aluminum rod? </TD></TR></TABLE>
STICK WELDING !? cmon thats for buildings and structures n ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">I just need to do a few tacks here, someone help me out. </TD></TR></TABLE>
wont happen unless your welder is made for it. mig with a steel wire etcc or if you dont have a spool gun. itll just bounce right off.
just use wide masking tape!! that's how i did my pipes.
tape everything how you like it and then use a sharp blade and cut out two places for a pro to tack it together... then he can take the rest of the tape off, clean it and weld you up some perfect IC pipes..
I'm doing another pipe on Monday - I should snap some pics - it worked so well!
