Throwing CEL code 3 Map sensor
Old Jun 12, 2005 | 10:52 AM
D C 5's Avatar
Default Throwing CEL code 3 Map sensor
I switched the map sensor with one that my friend had but its still throwing the code..... can anyone help me????? should i buy a new one???
Modified by 95RedCoupe at 1:29 PM 6/12/2005
Modified by 95RedCoupe at 9:59 PM 6/12/2005
Old Jun 15, 2005 | 09:54 AM
bmw626's Avatar
Default Re: Throwing CEL code 3 Map sensor (95RedCoupe)
did you buy the right one? There is one for the firewall and one for the TB
Old Jun 15, 2005 | 10:14 AM
MONSTERZC's Avatar
most of the time when a map senor code is thrown its in the wiring and not the sensor. we have seen this alot in honda's. We check the code then replace the sensor same thing happens then we bust out the mm and the manny. and trace it to the problem source
Old Jun 15, 2005 | 10:17 AM
handa's Avatar
Default Re: Throwing CEL code 3 Map sensor (MONSTERZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC &raquo;</TD></TR><TR><TD CLASS="quote">most of the time when a map senor code is thrown its in the wiring and not the sensor. we have seen this alot in honda's. We check the code then replace the sensor same thing happens then we bust out the mm and the manny. and trace it to the problem source</TD></TR></TABLE>
3 things possible though: hose leak, wiring, or map sensor itself.
Old Jun 19, 2005 | 11:01 AM
Ch3mik's Avatar
Default Re: Throwing CEL code 3 Map sensor (bmw626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">did you buy the right one? There is one for the firewall and one for the TB</TD></TR></TABLE>\
uhh, one is a TPS and one is a MAP
FSUseminoleEM1
Feb 19, 2010 08:34 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
k4ff1n3
Sep 28, 2002 12:15 PM
