CRX hood solution?
Old Jun 12, 2005 | 06:07 AM
ne3ek's Avatar
Default CRX hood solution?
I have a b18a swapped in my 89dx right now, no problems but I will be swapping that for a b18b/b16 combo im building up.
so what I want to know is what are my options? I search the forums but couldn't fin what I wanted
I don't want a CF hood because I don't want to make the car a target
I won't buy one then paint it thats way too much $ for an apearance mods (I don't want to spend any money on the body because it's pretty beat as is)
I can't use JUST the jdm hood because then i'd need the whole front.. then I'm back to square one.. money wasted to me
So I wanna know if anyone came up with any other ideas?
I was considering welding in a lump from any other car with one, i know there were a couple.. dsm ect. any help would be great thanks!
Old Jun 12, 2005 | 07:16 AM
Autoworks's Avatar
Default Re: CRX hood solution? (ne3ek)
I'm sorry...but what is your question??
Modified by Autoworks at 4:46 PM 6/12/2005
Old Jun 12, 2005 | 07:31 AM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
so y do you need to swap out the hood
Old Jun 12, 2005 | 07:49 AM
Neiser's Avatar
i think that the 2.0L Neons have the perfect bump in the hood for what you looking for no?
Old Jun 12, 2005 | 07:52 AM
Autoworks's Avatar
Default Re: (Neiser)
I'm trying to figure out what he needs the "bump" in the hood for. The DOHC will fit without the bump. My hood was touching the cam cover on mine (B16), to fix it I took the hood off, grabbed the cutting wheel and cut out the subframe piece that was touching. Problem solved.
Old Jun 12, 2005 | 07:58 AM
stormy's Avatar
Default Re: (Autoworks)
some people put a couple of washers between the motor mount and braket to lower the motor
Old Jun 12, 2005 | 08:39 AM
ne3ek's Avatar
the b16 has a shorter deck
the b18 vtecs sit much higher making the hood fit retarded
the washer idea sounds good, but the oil pan is low enough im not sure if i'd want to lower even more lol
neon lump sounds the best so far
meheartmycivic
Jun 16, 2010 06:54 PM
jbell
Aug 28, 2005 01:13 PM
crxzcracer
Mar 17, 2005 06:31 AM
Jared
Dec 25, 2003 01:34 PM
EBP TEG
Oct 13, 2001 11:23 PM
