eg h22 radiator
just had a quick question and didnt know where it belonged. im going to be driving from Mississippi to Houston this weekend and takes about seven hours to get there. i only have stock civic radiator with a slim fan on my h22..will it be enough to keep the car from overheating?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">Drove 11 hours to South Florida, and 11 back with a Fluidyne ... I don't see why the stock radiator shouldn't be able to handle it.
well, a fluidyne is about 50 times better than a stock civic radiator. i wouldnt trust those little pieces of **** stock radiators.
</TD></TR></TABLE>well, a fluidyne is about 50 times better than a stock civic radiator. i wouldnt trust those little pieces of **** stock radiators.
lol yeah teh fluidyne radiators are way better than the stock ones..im not so sure if its safe or not most ppl are telling me that it is safe. i would buy a dual core radiator but im short on cash
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmilf »</TD></TR><TR><TD CLASS="quote">lol yeah teh fluidyne radiators are way better than the stock ones..im not so sure if its safe or not most ppl are telling me that it is safe. i would buy a dual core radiator but im short on cash</TD></TR></TABLE>
Save your cash, you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">
I've been running the same one for over a year on my swap without ever seeing a sign of overeheating.
</TD></TR></TABLE>I've been running the same one for over a year on my swap without ever seeing a sign of overeheating.
does anyone have an clearance issues with the fluidyne 92-00 civic half sized radiator in their h22 swapped eg? Particulary I'm lookin at the bleeder valve for the slave cylinder wondering if a 1.5" in core will fit??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">i have the fluidyne half radiator in my h22/eg. its a close fit, the bleeder valve sticks in the fan a little bit but it doesnt hit the fan blade. </TD></TR></TABLE>
That's weird, mine is fine. I ran downstairs and took a couple quick pictures.
EDIT---After posting, I just realized that you probably have either a stock fan or front mount fan. It's more efficent to mount it pusher style. It flows more air and saves more room!
well, actually i now have my fan mounted as a pusher but for some reason, when its hot outside, my water temperature gets very high, higher than it did when i had my other fan mounted puller. the fan does turn on, and it is a pusher fan that i bought from pep boys about 3 years ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer »</TD></TR><TR><TD CLASS="quote"> Seen plenty of guys just run the stock civic rad with no problems. </TD></TR></TABLE>
still running my stock rad/fan that came with my d15b7. The temp guage needle makes it one mark low of the half mark on the guage and never moves. I was thinking about switching for a push fan instead of a pull though. I don't have much clearance for the stock fan, its just enough to work.
quick question. is the del sol dual core radiator the same size as a stock civic radiator? and if i get a del sol daul core radiator does it have to be form a B16 del sol? I have a stock radiator and a FAL fan on my H22 civic. I live in denver if i run it at 70-75 MPH the temp gauge never moves but if i drive it @ 80 MPH for about 25 mins the temp gauge stays half way and if i race somebody in the heat temp gauge goes really high?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A_civic »</TD></TR><TR><TD CLASS="quote">quick question. is the del sol dual core radiator the same size as a stock civic radiator? and if i get a del sol daul core radiator does it have to be form a B16 del sol? I have a stock radiator and a FAL fan on my H22 civic. I live in denver if i run it at 70-75 MPH the temp gauge never moves but if i drive it @ 80 MPH for about 25 mins the temp gauge stays half way and if i race somebody in the heat temp gauge goes really high? </TD></TR></TABLE>
Not exactly the same size no, its a bit thicker but it does fit in the same place as your stocker.
Superhatch
24
Sep 20, 2004 10:13 AM
