compression test
what are the numbers for 12:5:1 i ran a comp. test today and got 160 all the way across i mean isnt that kinda low for 12:5:1 comprssion
and i just did a search and if i didnt test at WOT does it make a big difference
what cams are you running?
cams with lots of duration will yield lower compression readings. As long as they're all within 15% of each other, its all gravy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex »</TD></TR><TR><TD CLASS="quote">what cams are you running?
cams with lots of duration will yield lower compression readings. As long as they're all within 15% of each other, its all gravy</TD></TR></TABLE>
20vsleeper
Aug 23, 2007 06:27 AM
bxsi
Apr 2, 2004 05:42 AM
