Fill Trans Fluid thru Vss Hole?
Old Jun 11, 2005 | 04:39 PM
Stoich's Avatar
Default Fill Trans Fluid thru Vss Hole? / Jdm ITR TB question
Can i fill the trans fluid thru the VSS hole? i got it out to do some work on it and it looks like a cleaner way to fill the trans
Modified by Stoich at 5:09 PM 6/12/2005
Old Jun 11, 2005 | 05:03 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Fill Trans Fluid thru Vss Hole? (Stoich)
How will you know when it is full?
I usually run a hose from a topside funnel to the fill port.
Old Jun 11, 2005 | 05:09 PM
Flux's Avatar
Default Re: Fill Trans Fluid thru Vss Hole? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I usually run a hose from a topside funnel to the fill port.</TD></TR></TABLE>
When it starts to come out the hole you are done...
Old Jun 11, 2005 | 05:10 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Fill Trans Fluid thru Vss Hole? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
When it starts to come out the hole you are done... </TD></TR></TABLE>
LOL! Just throw some paper on the floor.
Old Jun 11, 2005 | 05:11 PM
Stoich's Avatar
the manual says 4 qts
Is that right?
Old Jun 11, 2005 | 05:21 PM
Dogginator's Avatar
Daisy... Daisy...
The factory service manual says 2.3 qt for a fluid change or 2.4 qt for an assembly.
Old Jun 11, 2005 | 05:22 PM
vtec.dc2's Avatar
i just do it throuhg breather hole so no need to mess with vss and nothing to unscrew.. obviously i open the fill hole and wait until it starts to run out from there..
Old Jun 11, 2005 | 05:26 PM
sackdz's Avatar
Default Re: Fill Trans Fluid thru Vss Hole? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i just do it throuhg breather hole so no need to mess with vss and nothing to unscrew.. obviously i open the fill hole and wait until it starts to run out from there.. </TD></TR></TABLE>
me too... **** fills soooo sloowwwwwww tho
Old Jun 11, 2005 | 05:34 PM
Bbasso's Avatar
measure 2.3 qts and dump it in... No need to watch to see if it comes out the side hole, If you actually drained all the old stuff out
Old Jun 11, 2005 | 05:43 PM
Stoich's Avatar
Default Re: Fill Trans Fluid thru Vss Hole? (Bbasso)
yeah i drained it all out for service and i have the Vss out anyway to replace it and i wanted to know if i could just dump the 2.3L thru there
Old Jun 11, 2005 | 05:45 PM
Bbasso's Avatar
Dump it in
Old Jun 12, 2005 | 02:37 AM
Stoich's Avatar
Sweet thanks for the replys .
Old Jun 12, 2005 | 05:42 AM
b19coupe's Avatar
Just don't use gear oil
Old Jun 12, 2005 | 08:10 AM
Stoich's Avatar
Default Re: Fill Trans Fluid thru Vss Hole? (b19coupe)
Na i got OEm honda trans fluid.
on a side not can anyone name what the 3 metal nipples on the Jdm TB are for?
i got them all hooked up except for the one on the bottom.
Its going in to a Ef chassis BTW
Old Jun 12, 2005 | 09:47 AM
B2FiNiTY's Avatar
The bottom one goes to the intake manifold and carries coolant.
Old Jun 12, 2005 | 09:48 AM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">the manual says 4 qts
Is that right?</TD></TR></TABLE>
you obviously dont have a honda hamual.
throw yours in the trash.
Old Jun 12, 2005 | 11:31 AM
KOALA YUMMIES's Avatar
Default Re: Fill Trans Fluid thru Vss Hole? (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">
throw yours in the trash. </TD></TR></TABLE>
But d00d its still filling up! keep going!
-DC2-
Jul 12, 2007 06:36 PM
RenzoDaPlayboi
May 12, 2007 06:42 AM
B16b-EJ8
Sep 11, 2006 02:17 PM
RemerLex11
Nov 5, 2004 07:23 PM
Cyphear
Jun 20, 2004 03:51 PM
