TRICKFLAHSER SPECIAL PROMOTION for Honda-Tech $33 (MSRP $45)
Old Jun 11, 2005 | 03:33 PM
Yoshi900's Avatar
Default TRICKFLAHSER SPECIAL PROMOTION for Honda-Tech $33 (MSRP $45)
http://www.trickflasher.com
Trickflasher - a highly sophisticated microprocessor controlled flasher relay.
Unlike OEM (stock) flasher relay, which can only flash at a boring fixed rate. The Trickflasher can flashes the signal lights at varying rates, pulses and brightness. It is pre-programmed with four different pattern and one OEM pattern.
To purchase Trickflasher at the Special Honda-Tech promotion price,
click on link
http://www.trickflasher.com/2005/hondatech.htm
Modified by Yoshi900 at 12:43 AM 6/12/2005
Modified by Yoshi900 at 12:44 AM 6/12/2005
Old Jun 12, 2005 | 01:10 AM
GaiSensai`'s Avatar
Default Re: TRICKFLAHSER SPECIAL PROMOTION for Honda-Tech $33 (Yoshi900)
interesting!
Old Jun 12, 2005 | 05:40 PM
Yoshi900's Avatar
Default Re: TRICKFLAHSER SPECIAL PROMOTION for Honda-Tech $33 (GaiSensai`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaiSensai` &raquo;</TD></TR><TR><TD CLASS="quote">interesting! </TD></TR></TABLE>
Thanks GaiSensai.
Even the flash animation doesn't do justice to how eye catching the signal becomes with the Trickflasher, especially at night. And it is not annoying like those double or triple flashing rate relay.
If none of the four built-in pattern fit your taste, we can also do custom programmed pattern also.
Old Jun 12, 2005 | 08:08 PM
tunerzimage's Avatar
Banned
hmmm not bad. Is it plug and play?
Old Jun 12, 2005 | 09:00 PM
Yoshi900's Avatar
Default Re: (importindustries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importindustries &raquo;</TD></TR><TR><TD CLASS="quote">hmmm not bad. Is it plug and play?</TD></TR></TABLE>
Yes it is plug and play. (no need to cut any wire).
The general installation instruction is here.
http://www.trickflasher.com/20...r.pdf
For all Honda/Acura, there is only one style of relay. So this supplimental instruction would literally make it a 1-2 minute install job.
http://www.trickflasher.com/20...a.pdf
Old Jun 13, 2005 | 09:07 PM
Gant's Avatar
u should have a real life video on your site, pretty intresting
Old Jun 13, 2005 | 09:20 PM
Yoshi900's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">u should have a real life video on your site, pretty intresting</TD></TR></TABLE>
Ba4, thanks for the suggestion.
I've tried recording it on a digital camera (mpeg movie), but the flashing does not come out right. The signal light looks brighter that it is, and the signal looks to stay on longer than it actually is. It might have something to do with the camera sensor. Maybe it can be recorded better with proper lighting in a studio.
Old Jun 14, 2005 | 06:08 AM
jmayhew's Avatar
Default Re: (Yoshi900)
interesting...& cheap enough so its easy to test out.
Old Jun 15, 2005 | 08:30 PM
Yoshi900's Avatar
Default Re: (jmayhew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew &raquo;</TD></TR><TR><TD CLASS="quote">interesting...& cheap enough so its easy to test out. </TD></TR></TABLE>
Thanks for the jmayhew.
Old Jun 16, 2005 | 11:25 AM
Boofster's Avatar
We got one and tried to install on a Mazda 6. Unfortunately their relay has like 20 pins so we're going to have to do some major rewiring. Do you have a diagram for that relay?
Then we plugged it into the standard 3 prong Honda relay on my Integra just to see how it works. Patterns are neat and easy to control. I just wish there were jumpers or dials to make your own pattern (maybe based on 3 or 4 levels) or maybe some kind of network interface so you can upload/change the patterns. I would pay $80 if it had a USB plug and could store custom patterns.
Old Jun 17, 2005 | 04:35 PM
Yoshi900's Avatar
Default Re: (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">We got one and tried to install on a Mazda 6. Unfortunately their relay has like 20 pins so we're going to have to do some major rewiring. Do you have a diagram for that relay?
Then we plugged it into the standard 3 prong Honda relay on my Integra just to see how it works. Patterns are neat and easy to control. I just wish there were jumpers or dials to make your own pattern (maybe based on 3 or 4 levels) or maybe some kind of network interface so you can upload/change the patterns. I would pay $80 if it had a USB plug and could store custom patterns.</TD></TR></TABLE>
Hi Boofster,
I'll check to see if the Trickflasher can be wired up to the Mazda. What year and model is the Mazda?
Thanks for the suggestion also on the USB. We wanted to come out with a lower cost unit first, thus without any user programmable feature. The general US market for aftermarket product is very price sensitive. The next goal for the Trickflasher is to cover as many model as possible. In the meanwhile, we do offer custom pattern for a fee. Contact us at info@trickflasher.com
Old Jun 19, 2005 | 11:22 AM
Synergy001's Avatar
kind of reminds me of the old japanese ones. they had two version. the high speed flasher and the latin beat flasher. you can adjust the speed on those with a **** (probably a potentiometer). but anyways nice invention.
Old Jun 19, 2005 | 11:57 AM
SoCal_INTEGRA's Avatar
Default Re: (Synergy001)
OMG this is one Hot item!!!! *Bump*
So is it $33 shipped??? Very Interested in buying
Old Jun 20, 2005 | 05:22 AM
jmayhew's Avatar
Default Re: (SoCal_INTEGRA)
is there a way to adjust the speed....i would like one setting to be just the normal flash but faster.
is that something easy to do or is that one of the special setting that would have to be customly done?
Old Jun 20, 2005 | 07:22 AM
Yoshi900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to adjust the speed....i would like one setting to be just the normal flash but faster.
Hi jmayhew,
The Trickflasher does not have any speed adjustment. It will have to be a custom programmed unit.
Please email us at info@trickflasher.com and we will discuss if we can accomdate your request.
Regards,
Modified by Yoshi900 at 8:38 AM 6/30/2005
Old Jun 29, 2005 | 11:40 PM
Yoshi900's Avatar
bump
Old Jul 4, 2005 | 08:40 AM
bdaddy's Avatar
please send me payment details!! very interested!!
Old Jul 5, 2005 | 03:17 AM
menkio's Avatar
Default Re: (bdaddy)
is this street legal ?
Old Jul 5, 2005 | 08:19 AM
Boofster's Avatar
Default Re: (menkio)
I found use for this only for show. Had to plug back my regular relay because there is a 1sec delay which is not practical for daily driving. They use that 1sec for programming so there's no way around it.
Old Jul 5, 2005 | 10:14 AM
Yoshi900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdaddy &raquo;</TD></TR><TR><TD CLASS="quote">please send me payment details!! very interested!!</TD></TR></TABLE>
click on linkhttp://www.trickflasher.com/2005/hondatech.htm
Old Jul 5, 2005 | 10:35 AM
Yoshi900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">is this street legal ?</TD></TR></TABLE>
State law vary between different state, so we cannot say for sure.
In California, we were not able to find any specification for the signal flashing rate.
None of the customer had complain to us that they were hassle by the cop, so I do not believe it is a problem.
The Trickflasher can switch to OEM flashing very easily, so you can also switch back to regular flashing.
Old Jul 5, 2005 | 10:39 AM
Yoshi900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">I found use for this only for show. Had to plug back my regular relay because there is a 1sec delay which is not practical for daily driving. They use that 1sec for programming so there's no way around it.</TD></TR></TABLE>
Hi Boofster,
I've sent you a reply to your PM. Maybe you didn't check message lately. But the long delay is not normal. Please email us at info@trickflasher and we will take care of the problem.
The Trickflasher has a 1/2 second delay to look for user input for programming, so it should not be such a long delay that you'll finish your turn before it comes on.
Old Jul 5, 2005 | 06:51 PM
BB6-213's Avatar
just purchaced one
Old Jul 6, 2005 | 12:57 PM
Yoshi900's Avatar
Default Re: (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">just purchaced one</TD></TR></TABLE>
Thank you BB6-213. Your Trickflasher will be shipped out today.
Feel free to email us at info@trickflasher.com if you have any question on installation or operation.
Old Jul 9, 2005 | 12:51 AM
96axionhatch's Avatar
Default Re:
I bought one last week and it works GREAT . I think it helps get other drivers attention when changing lanes . THANKS.
