the maintenance required light?
Old Jun 11, 2005 | 03:24 PM
thelonerangers's Avatar
Default the maintenance required light?
when that comes on wat needs maintenance, is it like oil change, full tune up?
Old Jun 11, 2005 | 03:27 PM
jlacoy82's Avatar
71.192.16.183
Default Re: the maintenance required light? (ian22)
It comes on every 7,000 miles, if you do regular oil changes/maintenance on your car, dont worry about it. I reset it every time I change my oil.
Just take your car key, and put it up against the little black "button" to the side of the "light" (its actually a wheel like your odometer, but instead of numbers, its colors" and press down hard. It will feel pretty stiff, but it will pop down, and reset the indicator to green.
Old Jun 11, 2005 | 03:28 PM
neutron91's Avatar
that light is ridiculous... just make sure to change your oil/trans fluid/coolant/etc when it needs to be and just keep an eye on everything... if i were you i would just turn it off
Old Jun 11, 2005 | 03:30 PM
Default Re: the maintenance required light? (neutron91)
i just bought the car, should i take it in for an oil change or bring it to my mechanic for a tune up?
Old Jun 11, 2005 | 03:32 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian22 &raquo;</TD></TR><TR><TD CLASS="quote">i just bought the car, should i take it in for an oil change or bring it to my mechanic for a tune up?</TD></TR></TABLE>
Change oil, plugs, wires, PCV valve, and check the cap and rotor to see if they require replacement. Then I would recomend a tranny service. After that it should be good to go.
Note: This is what I do everytime I buy a used car the day I buy it.
civicb16eg
Honda Civic (2006 - 2015)
12
Aug 6, 2008 04:24 PM
bausts
Mar 13, 2007 10:30 AM
microsoft_sux
Aug 25, 2004 05:12 AM
blackriceman
Mar 29, 2004 08:33 PM
:jdmshmaydm:
Jun 19, 2003 06:44 AM
