Help!! how do i add back my FITV
Old Jun 11, 2005 | 03:00 PM
srv3fender's Avatar
Default Help!! how do i add back my FITV
Ok so ive been having problems with idle speed going down when i turn on the ac or the
radiator fan comes on so i read that its the fitv, will i go to adjust it and the guy before me plug the hole with a bolt and removed the fitv. So i have to get this fixed, i obtained
another manifold with a fitv and a better iacv on it and im gonna swap them out only problem is , the fitv on the new manifold has a wire harness on it and i cant find on my car where it would plug up to .
What should i do
its a 88 crx orignially hf but im pretty sure the swapped it to mpfi manifold cause that whats in there now but i think it use to be dual point. Hope that helps
Ur help is greatly appreciated
Old Jun 11, 2005 | 05:34 PM
srv3fender's Avatar
Default Re: Help!! how do i add back my FITV (srv3fender)
its a pm6 ecu if that helps
Old Jun 11, 2005 | 06:32 PM
srv3fender's Avatar
ok, how bout a wiring diagram for a pm6?
srv3fender
Jun 11, 2005 06:53 PM
SJR
Dec 16, 2004 12:59 PM
b1reed
Dec 28, 2003 05:41 AM
zcivicz
25
Mar 31, 2003 06:24 PM
