can you put type r pistons in d16?
Old Jun 11, 2005 | 02:22 PM
subydoored's Avatar
Default can you put type r pistons in d16?
like the title says did a search found nothing. i would thing you can but not 100% sure. if so anything special you have to do.
ps if you find something in the search leave a link i did find anything on the topic.
Old Jun 11, 2005 | 04:44 PM
spyz34's Avatar
Default Re: can you put type r pistons in d16? (subydoored)
no you can't. Fitment is way different
Old Jun 11, 2005 | 04:49 PM
mar778c's Avatar
Community Builder
Community Influencer
No, but you can get high compression piston for a d16 easy.
Old Jun 11, 2005 | 05:33 PM
boosted_hatch_216's Avatar
Default Re: can you put type r pistons in d16? (mar778c)
just use a pm7 piston for high compression and if you wanted to get a bigger overbore you could get an oversized piston, id just use the pm7 and stick to that.
Old Jun 12, 2005 | 05:38 AM
subydoored's Avatar
Default Re: can you put type r pistons in d16? (boosted_hatch_216)
ok thanks guys
Old Jun 12, 2005 | 06:06 AM
SwissChEz82's Avatar
I believe the ITR piston fits an 84 mm bore and the D16 is only 75, the biggest bore I've heard of in a D series was 79 and it was a sleeved block.
guy_from_nerk
Feb 5, 2009 09:12 PM
LudeLooker
Feb 4, 2008 01:26 PM
hookups214
Jan 27, 2006 09:07 AM
96SR-V
Apr 13, 2002 02:45 PM
shamoo
Jan 29, 2002 05:50 PM
