tranny issues
hi I was wondering if anybody on here has had issues with the axle seals on an ls tranny,I have a crvtec and 12 psi of boost from t3 turbo. my question/ concern is I replaced my axle seals two and a half weeks ago because of a leak coming from the tranny that stopped the leak now it is leaking just as bad as before,do you think this is do to the forces exerted upon the axles while launching or just installer error, and if it is installer error (i did it myself) why would it seal for a short time before failing. Just wondering if anyone else has had a problem like this thanks for your guys time
are you sure it is your axle seals? make sure the mating surfaces on the axels are smooth, dont overfill your tranny, are the retainer clips good (i have seen a guy put axels in with no clip it would run and drive fine but when he tool it to the track the axles would come out therefore oil would too, or it is a installer error. It is not because of launching.
new_climber
Mar 27, 2008 05:05 AM
