damn blue interior
Old Jun 11, 2005 | 01:29 PM
cellardore's Avatar
Default damn blue interior
WELL... today not a good day... my 2000 civic got smashed in the *** by a damn escalade and since i wasnt driving my own car.. "friend was" he gave me a 89 CRX plus the money to fix my civic.. sooo the CRX has blue interior is there any way i can DYE the pieces or something so they wont peel and look like **** a week later...
Old Jun 11, 2005 | 01:56 PM
crxtreme89h's Avatar
Default Re: damn blue interior (cellardore)
Get SI interior. It's a pain in the *** to get paint to stick to interior plastic. You have to put some serious prep work into that plastic.
Old Jun 11, 2005 | 02:00 PM
slow_rex_will's Avatar
Default Re: damn blue interior (crxtreme89h)
I agree with crxtreme89h, you would be better off getting SI interior!
Old Jun 12, 2005 | 07:29 PM
usdmEHboy's Avatar
i feel your pain...i hate my blue interior
Old Jun 12, 2005 | 07:31 PM
b16_madman's Avatar
Default Re: damn blue interior (usdmEFboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmEFboy &raquo;</TD></TR><TR><TD CLASS="quote">i feel your pain...i hate my blue interior </TD></TR></TABLE>
x2
Old Jun 12, 2005 | 08:35 PM
99teggsr's Avatar
Default Re: damn blue interior (B16_madman)
Try Krylons new paint, Fusion. Its made for plastic, and says it wont crack or chip as long as you not knock or bend it for atleast 7 days. NO prep work either. I painted mine during the winter and still no chips or anything. But my interior is also sitting in the garage not being used or touched, maybe if it were in the car it would be a different story. Anyway, its worth the ~3$ a can price if it saves you from buying a SI interior.
Old Jun 12, 2005 | 09:28 PM
Bigfootbuz's Avatar
The new Krylon paint does work really well, but I have found something really kool to do with my interior. Take some sheets of fiberglass, like the sheets you use when doing body work, some resin, and a sander. Clean each piece very carefully, and then line them with three sheets of fiberglass covering the entire area of the piece. Make sure you put a light coat of resin on the first piece. Let each sheet with resin dry about 15 minutes before you put the next on on. Then, once you have all pieces done, lay them out in the direct sunlight for about 2 hrs. That will allow for complete baking and drying of the resin and will harden the fibersheets to the max. Next, you need to sand the entire piece, first with a rough grit...(I don't remember what grit I used, or I would tell you), then with a fine one. Next, choose your color. Apply three coats for maximum shine and durability. I also hit mine with a clear coat, too. The finished product will look just like a professional showcar, real nice and shiny like the outside of the car. And, it will be hard, too, so there is no chance of breaking or bending them anymore. It also makes all interior panels unstainable, and unable to hold any sort of odor. I am totally thrilled with my work. From, beginning to end, taking each piece out, keeping all screws and mounts, lining, sanding, drying, and reinstalling, took me about 8 hrs and about $100. When you are done, it will be amazing. Also, I do not recommend that you use spray cans, it will look like ****. I used my own air compressor with a Wagner paint gun and paint. Just remember the old sayin, you get what you pay for. If you buy **** paint, and don't sand very good, it won't be worth a ****. Ne-wayz, it is a lil bit of work, but very well worth it. I am the talk of the town with my glossy interior. Good Luck!!
Old Jun 13, 2005 | 11:19 AM
JokerTypeR's Avatar
Default Re: damn blue interior (Bigfootbuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigfootbuz &raquo;</TD></TR><TR><TD CLASS="quote">The new Krylon paint does work really well, but I have found something really kool to do with my interior. Take some sheets of fiberglass, like the sheets you use when doing body work, some resin, and a sander. Clean each piece very carefully, and then line them with three sheets of fiberglass covering the entire area of the piece. Make sure you put a light coat of resin on the first piece. Let each sheet with resin dry about 15 minutes before you put the next on on. Then, once you have all pieces done, lay them out in the direct sunlight for about 2 hrs. That will allow for complete baking and drying of the resin and will harden the fibersheets to the max. Next, you need to sand the entire piece, first with a rough grit...(I don't remember what grit I used, or I would tell you), then with a fine one. Next, choose your color. Apply three coats for maximum shine and durability. I also hit mine with a clear coat, too. The finished product will look just like a professional showcar, real nice and shiny like the outside of the car. And, it will be hard, too, so there is no chance of breaking or bending them anymore. It also makes all interior panels unstainable, and unable to hold any sort of odor. I am totally thrilled with my work. From, beginning to end, taking each piece out, keeping all screws and mounts, lining, sanding, drying, and reinstalling, took me about 8 hrs and about $100. When you are done, it will be amazing. Also, I do not recommend that you use spray cans, it will look like ****. I used my own air compressor with a Wagner paint gun and paint. Just remember the old sayin, you get what you pay for. If you buy **** paint, and don't sand very good, it won't be worth a ****. Ne-wayz, it is a lil bit of work, but very well worth it. I am the talk of the town with my glossy interior. Good Luck!!</TD></TR></TABLE>Post pictures.
Old Jun 13, 2005 | 11:20 AM
JokerTypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">
x2</TD></TR></TABLE>X3
However, I found a parts DX hatch with black. Working on converting as we speak.
Old Jun 13, 2005 | 01:10 PM
Kryogen's Avatar
yes, Red and silver DX CRX's and Civic HB's ...Will have black interior....so you dont just have to get Si interior.
Silver HF CRX's also have black interior, and for black doorpanels, the 88 & early '89 model Civic HB's will fit.
The only difference between the DX and HF models with black interior compared to the Si models is you dont get factory Recaro seats.
Old Jun 13, 2005 | 01:14 PM
d16efsedan's Avatar
Default Re: (Kryogen)
I have Black Interior already just waiting to find another crx to put it in good things to keep..
Old Jun 13, 2005 | 01:17 PM
T--Rex's Avatar
Default Re: damn blue interior (JokerTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">X3
x4
Old Jun 13, 2005 | 01:20 PM
turboLSef's Avatar
has anyone ever tried aerosol dye??
http://www.autostyles.com/sem.htm
people say it works well but I have no personal experience with it..
Old Jun 13, 2005 | 01:27 PM
aeonsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">yes, Red and silver DX CRX's and Civic HB's ...Will have black interior....so you dont just have to get Si interior.
The only difference between the DX and HF models with black interior compared to the Si models is you dont get factory Recaro seats.</TD></TR></TABLE>
watch out for std hatchs though (HF crx's maybe too but not positive) they are the same colors but the door panels dont have vinyl on the lower black area and the rear-sides dont have vinyl on them at all. just factory died plastic.
Old Jun 13, 2005 | 01:34 PM
Kryogen's Avatar
yeah, my bad, thx for reminding me about that, The Silver HF's dont have the fabric on the door panel, and I dont think any STD HB's even came with black.
Old Jun 13, 2005 | 01:36 PM
MONSTERZC's Avatar
Default Re: (aeonsi)
it doesnt take that much prep time on plastic sand primer then paint the clear coat
Old Jun 13, 2005 | 01:42 PM
93formula's Avatar
yup i wanna see some pics!
Old Jun 13, 2005 | 01:43 PM
tallguy's Avatar
Default Re: (MONSTERZC)
I used paint for mine and its not peeling yet, but i still got the blue seats i hate them. GSR leathers going in soon.
Old Jun 13, 2005 | 02:19 PM
g2tegsown's Avatar
Don't feel bad the guy I bought my CRX from painted the interior some hideous red color, and it's chipping
So my best bet would be to just buy new interior? Anyone know a store that has carbon fiber dash kits/interior?
I love carbon fiber.... mmmmm........
Old Jun 13, 2005 | 04:15 PM
JokerTypeR's Avatar
Default Re: (g2tegsown)
Bleh @ unpainted carbon. it's a material..not a style.
However, check with Nopi.com. If anyone has them, I'm certain they do. Or riceloversplus.com JKJK, each to their own.
Your other options is to possibly look into a local upholstry shop and see if maybe they can pull something for you. Maybe you can even get a fancy material or something if you're goign that route. Mm...rice-velvet. hehe.
Good luck with whichever your route is though.
Old Jun 13, 2005 | 06:20 PM
Eaglekper0046's Avatar
Default Re: (JokerTypeR)
I painted mine with Dupli Color vinyl and plastic spary paint [URL][/Uhttp://www.kodakgallery.com/BrowsePhotos.jsp?&collid=138441372205&page=1&sort_ order=0RL]
Old Jun 13, 2005 | 06:40 PM
steronz's Avatar
embrace the blue! i think it looks good, depending on the exterior color. i'd love to see black w/ blue interior.
Old Jun 13, 2005 | 06:58 PM
93formula's Avatar
Default Re: (steronz)
but black on black is much nicer
Old Jun 13, 2005 | 07:13 PM
kurinto's Avatar
Default Re: (93formula)
I recovered my door panels with black vinyl. I'm working on a how-to once I finish them.
Old:
New:
Old Jun 13, 2005 | 07:25 PM
Jonathan_ED3's Avatar
Those look pretty much the same to me.
And as far as the fiberglass dashboard....who in the WORLD wants a fiberglass dashboard?! WTF?
