clearance issues with ITR crank and rods in a b16b?
Old Jun 11, 2005 | 10:28 AM
EK9 BEEZLER's Avatar
Default clearance issues with ITR crank and rods in a b16b?
I'm thinking about throwing a type r crank and rods into my b16b. would i run into problems with the pistons hitting the valves because of the different rods? also do you guys know how much compression i would have after doing this?
Old Jun 11, 2005 | 10:31 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clearance issues with ITR crank and rods in a b16b? (EK9 BEEZLER)
I think that would cause a problem. B18 deck height is slightly taller than a B16.
As for the compression, http://www.c-speedracing.com
Old Jun 11, 2005 | 10:35 AM
b16B uses a p72 block, same as a b18c
Old Jun 11, 2005 | 11:59 AM
no one knows?
Old Jun 11, 2005 | 12:14 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9 BEEZLER &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about throwing a type r crank and rods into my b16b. would i run into problems with the pistons hitting the valves because of the different rods? also do you guys know how much compression i would have after doing this?</TD></TR></TABLE>
You'll basically just have an ITR motor with CTR pistons, which has been done many times. You shouldn't have any valve-to-piston clearance issues, and compression will be somewhere in the low 12's (depending upon who you ask).
boostincoupe
Mar 13, 2007 05:42 PM
GOLDBERG
12
Jun 10, 2003 09:13 AM
Acura_I-RS
Jan 2, 2003 08:40 PM
DAYUIZ
Apr 11, 2002 02:52 PM
