Electrical problems...
Alright guys a few weeks ago I had a problem where my car wouldn't start one day and then after jumping the battery and driving the car the gauges were jumping all over the place and then stopped after a few minutes of driving. I got the car home, let it sit about 10 minutes, and it wouldn't start again. I figured it was my alternator so I replaced it with one that my buddy had from a 99 civic. It started up just fine after that and I didn't have any problems until today.
Today when I was at the track the car randomly decided it didn't want to start again so I had someone push start me. I let the car run for the entire night at the track and then after I got home the car seems to want to start fine now. Is this alternator dead to, is the battery on its last leg, or is it something else?
PS: I couldn't test the first alternator that went bad because the stud that holds the power wire for the alternator broke off so i never figured out if that was the problem for sure.
I haven't checked the battery yet. Its about 2 years old though I believe. It sounds like it may be a ground because the car is mysteriously starting just fine now.
the guages will sometimes act up with a bad alternator. I would test the battery when it is running with a volt meter. should be about 13.5 -14.3 volts. if it is way up in the 15-16's, the battery is bad. if it is in the 12's and doesn't go up when the engine is reved up. Then go buy a new altenator.
well i think i figured it out. The nut holding the cable onto the alternator was kinda loose and the strap was moving around and not getting a good connection. I tightened it back down and it now has a higher running voltage. I guess the nut vibrated loose or something.
94HybridEX
Oct 10, 2002 10:06 AM
