Driving in main oil seal (behind flywheel, help!!!)
Old Feb 10, 2002 | 01:56 PM
AmauryR's Avatar
Default Driving in main oil seal (behind flywheel, help!!!)
Ok, whats the safest (or easiest) way to drive in the rear main oil seal? I already put in the front main seal (near oilpump), but this one's giving me trouble going in. Thanx. (Oh, and I did do a search, but nothing as far as driving in the seal came up).
Old Feb 10, 2002 | 03:14 PM
iceburgslim's Avatar
Default Re: Driving in main oil seal (SKiLLz-R)
A rear main seal tool, get one at your honda dealer...unless you can find a socket as big in diameter as the seal. Then you just place the socker over the seal and tap it in with a hammer.
Old Feb 10, 2002 | 03:15 PM
Jared's Avatar
I like using a rubber mallot.
Old Feb 10, 2002 | 07:27 PM
AmauryR's Avatar
Default Re: Driving in main oil seal (Jared)
Yeah, I have a cheapo haynes manual and it says to use a 1/2" extension and "tap" the seal inplace, looks easy enough - but I'm gonna try the rubber-mallot idea. I was thinking of getting a socket-big enough, but damn. Das a big socket!!! Thanx ppl. I'll let u know how it plays out.
Old Feb 11, 2002 | 08:26 AM
adamp35's Avatar
New User
is the motor out of the car??
Old Feb 11, 2002 | 09:41 AM
rainforest's Avatar
Default Re: Driving in main oil seal (adamp35)
2cd the rubber mallot
Old Feb 11, 2002 | 10:18 AM
Crazydave's Avatar
Default Re: Driving in main oil seal (rainforest)
Make sure that you get it in all the way.. otherwise it will rub against your flywheel..
and you will have to do it all over again
Old Feb 11, 2002 | 11:05 AM
AmauryR's Avatar
Yeah, I'm doing all of the major crap w/ the motor out of the car before I drop it in. Alls I have left to replace is this main seal, that and wait for my lightened fywheel to come in ups, and I'm set to drop the biatch in!
Old Feb 13, 2002 | 07:01 PM
adamp35's Avatar
New User
well since it is out of the car, us a 2x4 piece of wood and a ruber mallet. Place the wood flat on the seal the long way(flat side not the butt end of it.) Then tap it with a rubber mallet. Turn the wood block around the seal several different angles so that it drives in evenly... tap twice, then turn the wood a little, tap it twice, then turn the wood some more... keep repeating until it is flush with the surface. Then you should have no problem with it touching the flywheel, and if you are patient and don't hammer it too hard, you will not ruin your seal.
good luck!!
ADAM
dads95ss
Jul 14, 2012 07:45 PM
Skitso's CB7
May 5, 2011 10:22 PM
folta2169
Sep 3, 2007 01:50 PM
Fatty_1775
Aug 23, 2006 03:23 AM
johnzm
Sep 30, 2002 11:31 AM
