blowin ECU fuse
Old Feb 10, 2002 | 01:56 PM
BTR ALL MOTOR's Avatar
Default blowin ECU fuse
hey guys, i keep blowin my ecu fuse....what is the deal with that? is it a short somewhere or what?
Old Feb 10, 2002 | 03:18 PM
Jared's Avatar
Default Re: blowin ECU fuse (BTR ALL MOTOR)
tons of different connections will blow that ECu fuse, injector short, o2 short, iacv short, etc.. time to get a shop manual and start hunting.
Old Feb 10, 2002 | 05:14 PM
Default Re: blowin ECU fuse (Jared)
what if the ecu fuse blows when i turn on the power only and not start the motor???
Old Feb 11, 2002 | 01:20 PM
bob01721's Avatar
Then you have a short somewhere and you need to get some wiring diagrams to hunt it down.
Old Feb 12, 2002 | 10:59 AM
Perfectionist's Avatar
Stick your nose on the ECU and sniff. Does it smell burned? There is a diode that has burned up on some ECU's and caused the fuse to go. Best thing to do would be borrow someone's ECU and see if it corrects the problem. However, if you've got a 'bad thing' somewhere, you could fry the loaner ECU too.
If you've done some serious mods and hacked into the wire harness, start there and double check your splice jobs.
94SuperLudeSI
Apr 20, 2008 06:10 AM
KrispyKreme
Aug 31, 2005 05:32 PM
Simple
May 16, 2003 10:11 AM
lopey
May 1, 2002 11:26 AM
