b16a swap question
Old Jun 10, 2005 | 08:40 PM
jake1511's Avatar
Default b16a swap question
ok im swapping a b16a into a crx si and i have a question about the 90-93 iintegra axels/intermediate shaft for the swap...
do i need to modify them for them to fit or will they just fit right in?
Old Jun 11, 2005 | 12:02 AM
oneforce's Avatar
Default Re: b16a swap question (jake1511)
just did a first gen. b16a swap yesterday on a 89 crx, integra axles and shaft is perfect for the swap.(note) you will have to unbolt one one the nuts to fit the axle into place, because the integra axle is too big. plus i had trouble putting on the driver side axle into the shaft, just have to move the axle around to fit perfectly, no biggy... hope this helps u
Old Jun 11, 2005 | 05:36 AM
jake1511's Avatar
nice
thanks a bundle
Old Jun 12, 2005 | 08:23 PM
jake1511's Avatar
2nd question...
will any b-series shift linkage work with this swap?
or do i need custom linkage?
Old Jun 12, 2005 | 08:33 PM
Redline130's Avatar
Default Re: (jake1511)
You will need a custom linkage. Or you can cut the B-series one, just not sure how much.
EL Vap133's Avatar
Custom linkage, or a JDM SiR shift linkage for an EF.
d-mill
Classic Hondas
Aug 5, 2010 05:05 PM
EasternBandit
Jul 15, 2009 07:53 AM
ef8sleepr
Apr 12, 2006 02:11 AM
I3ackfire
Mar 17, 2004 01:52 PM
