question on B18b
Old Jun 10, 2005 | 06:37 PM
PowderB16's Avatar
Default question on B18b
i just swapped an auto 0bd1 b18b into my 94 civic and i bought an uncut wiring harness and changed out the basics to make the work easier since the motor was out, and i put on my manual ls tranny. the only problem is that when i get around 2-3k rpms it seems like it starts kicking, it seems normal before and after that point but i just cant think of what it would be, i changed everything from cap and rotor timing belt (before motor had been ran) and the ecu isnt throwing any codes, i thought it would be the injectors but i thought it would throw a code. the only things i havent changed are the fuel pump or the fuel filter. i also have b16 injectors and i was thinking of putting them on but it doesnt make sense. even when i turned up the FP i still wasnt getting much of a change, it was running 31 at idle and i turned it up to about 35. the spark plugs where a little white but that was before i put in the 02 sensor. any help would be greatly appreciated.
Old Jun 10, 2005 | 06:41 PM
neutron91's Avatar
Default Re: question on B18b (PowderB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PowderB16 &raquo;</TD></TR><TR><TD CLASS="quote">timing belt (before motor had been ran)</TD></TR></TABLE>
check timing
Old Jun 10, 2005 | 06:47 PM
PowderB16's Avatar
Default Re: question on B18b (neutron91)
yeah timing was 15 degrees
Old Jun 10, 2005 | 08:35 PM
PowderB16's Avatar
also, when it hits that point it sounds like the exhaust is popping, it sounds like its surging or something.............?
Old Jun 11, 2005 | 08:45 PM
PowderB16's Avatar
anyone have any ideas?
Old Jun 11, 2005 | 08:48 PM
DohctorVtec's Avatar
LS = Loud and Slow unless you turbo it
Old Jun 11, 2005 | 08:50 PM
PowderB16's Avatar
Default Re: question on B18b (DoctorVtec)
any reason for it kicking? motor is clean as hell, valves all seemed to work good, not too sure how the bottom end looks but everything seems to check out straight until driven, i also changed the fuel filter today.......... seems the exact same.
Old Jun 13, 2005 | 10:02 AM
PowderB16's Avatar
bumped for everyone whos stumped (including me.......)
somedude1717
Jul 13, 2016 12:11 PM
JoeCereghino
Nov 28, 2008 03:48 PM
AZNracerx1989
May 14, 2006 11:34 AM
domestic_rice
Mar 6, 2006 10:58 AM
