Firewall fuel filter fitting size
Old Jun 10, 2005 | 03:12 PM
Keith P's Avatar
Default Firewall fuel filter fitting size
I've searched and searched...
What size is the fuel fitting on the fire wall? Coming off of the hardline.
Thanks..
Old Jun 10, 2005 | 03:22 PM
Kryogen's Avatar
should be a 17mm if you can get a open end wrench on it, Honda and Snap-on and Mac sells a special tool just for those and theyre not that expensive either.
Old Jun 10, 2005 | 04:05 PM
Keith P's Avatar
Default Re: (Kryogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">should be a 17mm if you can get a open end wrench on it, Honda and Snap-on and Mac sells a special tool just for those and theyre not that expensive either.</TD></TR></TABLE>
I actually need the fitting size. It looks like an inverted flare. I know someone knows this..
Old Jun 10, 2005 | 04:31 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (Keith P)
Measurement of the banjo fitting is 12mm i.d. (13mm thick)
service bolt size is 12mm X 1.25mm pitch
Old Jun 10, 2005 | 06:08 PM
Keith P's Avatar
Default Re: (88DXCRX)
I'm not planning on reusing any of the stock fuel lines. I need to connect the hard line to a -6 hose. The fitting I'm questioning is the one on the end of the hard line on the fire wall.
Old Jun 10, 2005 | 06:23 PM
88DXCRX's Avatar
O.D. of the tubing is 8mm
Fitting is 14mm X 1.5mm pitch
Modified by 88DXCRX at 11:05 AM 1/27/2006
Old Jun 10, 2005 | 06:54 PM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
Fitting is 13mm X 1.5mm pitch
</TD></TR></TABLE>a -6 fits on that fitting perfectly, i did it to my car
Old Jun 10, 2005 | 07:16 PM
speeddave's Avatar
Default Re: (86si)
i was just wondering about this
Old Jun 11, 2005 | 04:41 AM
Keith P's Avatar
Default Re: (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">a -6 fits on that fitting perfectly, i did it to my car</TD></TR></TABLE>
That makes life SOOO much easier. THANKS!
Old Jun 11, 2005 | 12:20 PM
Keith P's Avatar
AN-6 didn't fit... Take a look at my 91 SI HB's fitting. I may need to cut it off and use a different flare fitting. Any help would be much appriciated.
Whats up with the straight section berfore the threads?
Old Jun 11, 2005 | 02:51 PM
SETI20's Avatar
&lt; subscribe
Old Jun 12, 2005 | 04:34 PM
Keith P's Avatar
Default Re: Firewall fuel filter fitting size (Keith P)
Bump for alternatives. I'm going to cut the end of the tube off. What type of flare fitting should I use? I have a flaring tool.
Old Jun 12, 2005 | 06:27 PM
86si's Avatar
i will take a pic of mine later, i did not cut it ...i know the flare is the diff. but it sealed with no leaks. did you try to thread the -6 on to it ?
Old Jun 12, 2005 | 06:55 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P &raquo;</TD></TR><TR><TD CLASS="quote">AN-6 didn't fit</TD></TR></TABLE>
Interesting, I want to see what happens.
Old Jun 13, 2005 | 04:14 AM
Keith P's Avatar
Default Re: Firewall fuel filter fitting size (86si)
Yes, it barley cought the first thread on the AN fitting. I honestly think I will have to cut this fitting off and re-flare it with a proper fitting.
Old Jun 13, 2005 | 04:59 AM
Davep's Avatar
Well I ran into this delema a few years ago and came up with this.
It's a custom made -6AN on one side and a 5/16" swagelok hard line adaptor.
I have one left I'll sell for $30 shipped.
Old Jul 2, 2005 | 07:45 PM
speeddave's Avatar
so what did you end up doing with this keith P?
Old Jul 3, 2005 | 10:18 AM
SETI20's Avatar
Default Re: Firewall fuel filter fitting size (speeddave)
Up, I wanna know too
Old Jul 5, 2005 | 05:05 AM
Davep's Avatar
He bought one of the fittings I made pictured above.
Old Jul 5, 2005 | 05:37 AM
Keith P's Avatar
Default Re: Firewall fuel filter fitting size (Davep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davep &raquo;</TD></TR><TR><TD CLASS="quote">He bought one of the fittings I made pictured above.</TD></TR></TABLE>
Yup.
I plan to cut the hard line on the cabin side, attach the swedge-lok, then use a nice 90 degree bulkhead fitting.
The only downside is this is a non-swivel fitting, so getting the bulkhead aligned is going to be an issue.
Old Jul 5, 2005 | 11:13 AM
SETI20's Avatar
Great. But that doesn't explain why 86Si's AN fitting did fit....
Old Jul 5, 2005 | 11:48 AM
Keith P's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Great. But that doesn't explain why 86Si's AN fitting did fit....</TD></TR></TABLE>
The thread may be close enough, but I would not trust it's ability to hold pressure. AN fittings use a 37 degree angle to seal, his AN setup would be using the threads to seal. A straight thread is not a reliable seal for fuel fittings.
The Swedge-loks are very well designed. I have faith that it will work.
Old Jan 27, 2006 | 08:15 AM
88DXCRX's Avatar
I originally had posted the size of the hard line as 13mm..
I made a mistake when measuring this as I had the calipers
too tight and was measuring inside the threads instead of
the exterior diameter of the fitting. Missed it by a millimeter...
Sorry for the mis-info...
<u>The correct size should be 14mm X 1.5mm pitch..</u>
Old Jan 27, 2006 | 08:26 AM
DocSean's Avatar
I was hoping to convert my stock inlet and return lines to accept my aftermarket fuel line AN fittings, is there any simple/easy approach to doing this? I am not familiar with flaring at all....but I can learn.
Old Jan 27, 2006 | 10:26 AM
Chase's Avatar
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">I was hoping to convert my stock inlet and return lines to accept my aftermarket fuel line AN fittings, is there any simple/easy approach to doing this? I am not familiar with flaring at all....but I can learn.</TD></TR></TABLE>
Hey man, i made a thread about this recently. The stock EF hardline isnt straight for long enough to use the tube nut, tube sleeve method of converting the hardline to AN fittings. I found this life saver tho at http://www.anplumbing.com. Its a 14mm x 1.5mm adapter. It screws on the stock tube nut and goes from 14mm x 1.5mm to -6AN.
Go to this link : http://www.anplumbing.com/shop...minum
and scroll down till you see Description: Fuel Injection adapter
Looks like this :
and BTW it works GREAT!
and as for the return line, just put the stainless hose on the hardline and tighten it with a worm clamp like stock. If you want the AN fitting look, these are really cool.... http://cgi.ebay.com/ebaymotors...wItem
Thats probably not the right size, im not sure what size to use, but just search Ebay motors for Spectre Hose end
