searched:( no fifth, no reverse
Old Jun 10, 2005 | 02:07 PM
91SiRX's Avatar
Default searched:( no fifth, no reverse
i realize the shift linkage needs to be altered when swapping the b16 into a crx, if the cut was too short or too long, would this make fifth gear grind and my reverse not work...it just started doing this so im really worried its in the transmission?
Old Jun 10, 2005 | 04:06 PM
kaoss_11's Avatar
B A N N E D
its very possible. also do you have a short shifter
Old Jun 10, 2005 | 06:03 PM
rainforest's Avatar
Default Re: (kaoss_11)
either that or a bent shift fork r and 5th are the same shift fork.
Old Jun 10, 2005 | 06:59 PM
Crx Jimmy's Avatar
Default Re: searched:( no fifth, no reverse (91SiRX)
just completely remove the shift linkage and put it in reverse manually by pushing or pulling on the piece that comes out of the tranny, and see if that does anything
Old Jun 10, 2005 | 07:41 PM
CRseXy's Avatar
Default Re: searched:( no fifth, no reverse (Crx Jimmy)
You didnt use Aftermarket Shift linkage did you? You modded the ones you have.
to be very frank, you probly fucked up, and you should go get some aftermarket linkage.
vtecislife
Jul 16, 2009 08:56 AM
Lokisdope
Apr 1, 2008 11:29 AM
UrVtecIsLoud
Jul 26, 2006 07:26 PM
SeaBass
Jul 9, 2003 10:25 PM
lsvtec101
May 2, 2003 08:17 AM
