smoking at de-accel
Old Jun 10, 2005 | 01:18 PM
ithrowpoop's Avatar
Default smoking at de-accel
i just recently noticed that my car is puffing blue smoke at de acceleration. i recently replaced the valve stem seals and the compression is good. any ideas, please help?
Modified by ithrowpoop at 2:51 PM 6/10/2005
Old Jun 10, 2005 | 01:21 PM
Chris F's Avatar
Default Re: smoking at de-accel (ithrowpoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ithrowpoop &raquo;</TD></TR><TR><TD CLASS="quote"> i just recently noticed that my car is puffing blue smoke at de acceleration. i recently replaced the valve guide seals and the compression is good. any ideas, please help?</TD></TR></TABLE>
valve seals. sorry.
Actually-- when I cracked a ringland, I would actually foul my spark plug with oil during deceleration, and would have to replace it to get it to start firing again. Take a look at your plugs, see if one is oily.
Modified by Chris F at 8:27 PM 8/12/2005
Old Jun 10, 2005 | 01:50 PM
ithrowpoop's Avatar
Default Re: smoking at de-accel (Chris F)
last time i looked the plugs were fine.
Old Jun 10, 2005 | 02:05 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ithrowpoop &raquo;</TD></TR><TR><TD CLASS="quote">last time i looked the plugs were fine.</TD></TR></TABLE>
How long ago was that, before or after the blue smoke you are noticing?
Old Jun 10, 2005 | 04:15 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ithrowpoop &raquo;</TD></TR><TR><TD CLASS="quote"> i just recently noticed that my car is puffing blue smoke at de acceleration. i recently replaced the valve stem seals and the compression is good. any ideas, please help?
Modified by ithrowpoop at 2:51 PM 6/10/2005</TD></TR></TABLE>
as mentioned before this is valve seal related.. smoke after letting of gas should be related to that. does it happen all the time?
Old Jun 11, 2005 | 12:30 PM
ithrowpoop's Avatar
Default Re: smoking at de-accel (vtec.dc2)
just checked, plugs are good.
Old Jun 11, 2005 | 01:36 PM
markpaco's Avatar
I had the same problem too. I would get some mean smokescreen on decel at the auto-x. It ended up being a hole in my valve cover breather hose. Try checking that.
Old Jun 11, 2005 | 02:02 PM
ithrowpoop's Avatar
Default Re: smoking at de-accel (markpaco)
i just replaced a cloged pcv valve and need to check it again. when i first noticed it the hoses to my catch can(pcv, to can, to intake manifold) were colapsed.
Old Jun 11, 2005 | 09:32 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem too. I would get some mean smokescreen on decel at the auto-x. It ended up being a hole in my valve cover breather hose. Try checking that.</TD></TR></TABLE>
Any theory on HOW those two things are related?
Old Jun 12, 2005 | 11:19 AM
markpaco's Avatar
I believe that if you equalize the pressure between the top of the cylinder head and the combustion chamber, the oil is less likely to get sucked down the valve guides. If you have a hole in the valve cover breather hose that goes to the intake manifold, the pressure differential will be between atmosphere and the negative pressure during the inhalation stroke. That is my theory.
Old Jun 12, 2005 | 12:34 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">I believe that if you equalize the pressure between the top of the cylinder head and the combustion chamber, the oil is less likely to get sucked down the valve guides. If you have a hole in the valve cover breather hose that goes to the intake manifold, the pressure differential will be between atmosphere and the negative pressure during the inhalation stroke. That is my theory.</TD></TR></TABLE>
theories.. gotta love them.. guess what.. i don't even have a valve cover hose.. my breather is open at all times. what you're saying is completely unrelated and makes no sence..
del sol1658
Mar 27, 2007 01:02 PM
Bassg26
Mar 9, 2007 06:03 PM
JoeCDN
Oct 14, 2004 09:50 PM
LuckyNuts
Sep 30, 2003 05:23 PM
stockgreencivic
Apr 26, 2003 02:41 AM
