Diamond Audio M661 6" Component Speaker System
Old Jun 10, 2005 | 09:39 AM
The Alchemist...
Guest
Posts: n/a
Default Diamond Audio M661 6" Component Speaker System
New - $130 firm... They cost over $200 online even.
Titanium Magnesium Alloy Cone - High rigidity, smooth linear response
Die-cast Alloy Chassis - High strength maintains critical parts alignment
Butyl® Rubber Surround - Uniform response, durable at environmental extremes
Machined Backplate/Pole - Precision engineered to exacting tolerance
Aluminum Dome Tweeters - Crisp, smooth response
Type: Component
Drivers: Tweeter, Midbass
Drivers per Channel: 2
Woofer Cone: Titanium-Magnesium
Tweeter Cone: Aluminum
Tweeter Mounting: Flush, Surface, Angle
Power Range (watts): 20-170
Imped (ohms): 4
Crossover Included: Y
Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 91
Freq. Response (±3dB): 46Hz-24KHz
Mount Dimension: Depth: 2-1/8" Diameter: 6-1/2"
Tweeter Dimension: Diameter: 1"
Might consider trades but I would rather get 130 cash for them.
Old Nov 23, 2008 | 05:17 PM
fc3srx729's Avatar
slowpokecivic
Dec 6, 2006 05:27 PM
slowpokecivic
Oct 17, 2006 08:51 PM
