Rotor Temps at 500 Degrees plus at track, is that a problem?
Old Feb 10, 2002 | 10:44 AM
onyx00's Avatar
Default Rotor Temps at 500 Degrees plus at track, is that a problem?
We measured the front rotor temps. right after a 20 minute session and they were 500 degrees on both rotors. Same goes for another ITR there. Is this a problem? Should I do anytihng about this in terms of upgrading the brake system, etc? Right now I have Hawk HP+ pads, Goodridge SS lines, and running ATE TYP 200 fluid. Stock rotors.
Thanks
Old Feb 10, 2002 | 10:46 AM
GRM Scott's Avatar
25 Year Member
Default Re: Rotor Temps at 500 Degrees plus at track, is that a problem? (onyx00)
If you're not loosing braking power, it's not a problem Your pads and fluid should be, and sound like they are, sufficient for those temps.
Old Feb 10, 2002 | 11:11 AM
Phoenix_ITR's Avatar
heh...just don't use the brakes as much. seriously though, it was nice talking to you and hopefully i'll see you around at some other track events.
--tony
Old Feb 10, 2002 | 01:50 PM
alu95's Avatar
Did you do a cool down lap? If so, you may have crossed Ate's boiling pt.
You may want to try R4/Blues/P+ if you start glazing your pads.
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
-al
Natural Aspirations
Suspension & Brakes
Sep 27, 2009 03:08 PM
PH3593A
Jul 28, 2004 03:14 PM
CD8
Jun 10, 2002 04:34 AM
Ghetto Racing
Jul 4, 2001 07:24 PM
