What Replacement Brakes for 4x114.3??
I did a search and couldn't come up with a definitive answer. When replacing brakes on the 4x114.3 ITR set-up, what pads and what rotors should be used? I read a few people saying that the discs are the same as GSR but with a different lug pattern. Does that mean that GSR pads can be used? What car do the rotors need to come from? Anyone?
Yes, the rotors have a different bolt pattern (4x114.3). I believe you can you can use prelude rotors? I'm guessing.
I actually have a complete front setup sitting in my garage. If you need any parts for cheap, lemme know.
94-97 gsr brake pads...92 prelude si non vtec rotors but you have to space the caliper from the hub with washers
Modified by egtype-r at 1:05 PM 6/29/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtype-r »</TD></TR><TR><TD CLASS="quote">94-97 gsr brake pads...92 si non vtec rotors but you have to space the caliper from the hub with washers</TD></TR></TABLE>
just to clarify, you mean 92 PRELUDE sinonvtec
DuongBros.
Suspension & Brakes
Oct 18, 2008 02:04 PM
DAchiko
Sep 11, 2007 08:06 PM
