Go with OEM or aftermarket on Water pump& Timing belt
Its almost time to change the water pump and timing belt. Is it a good idea to go with aftermarket parts? or stick with OEMS?
How much does the after market parts goes for?
I should be able to get BRAND NEW OEM ones for around $200 (Water Pump, Timing Belt, Cam & Crank Seals, Valve Cover Gasket, Spark Plug Well Seals,Valve Cover Grommets )
thanks
thanks
hilde123
Apr 26, 2010 06:19 PM
