claying motor for clearance
Old Jun 10, 2005 | 06:59 AM
( o )( o )'s Avatar
Default claying motor for clearance
I have read the c-speedracing howto on claying your motor for clearance. This is a big concern for me because I have a b16 with CTR pistons and a milled head. I paid a lot for a thick *** cometic head gasket. My question is - if I follow the how-to and torqued down the head on the gasket to press the clay, will i be able to reuse my custom gasket?
Thanks!
Old Jun 10, 2005 | 10:10 AM
( o )( o )'s Avatar
Default Re: claying motor for clearance (( o )( o ))
bump
Old Jun 13, 2005 | 12:05 PM
( o )( o )'s Avatar
bump - anyone?
Old Jun 13, 2005 | 04:28 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote"> I have read the c-speedracing howto on claying your motor for clearance. This is a big concern for me because I have a b16 with CTR pistons and a milled head. I paid a lot for a thick *** cometic head gasket. My question is - if I follow the how-to and torqued down the head on the gasket to press the clay, will i be able to reuse my custom gasket?
Thanks!</TD></TR></TABLE>
Could you? Sure.. Would I? No. You need to get an old used headgasket and do it with that.. Problem is your numbers will be off. Measure the difference in thickness between the old and the new gasket and add that to your clearance numbers and it will get you a little closer to the actuall numbers.
I still don't understand why people keep stuffing these pistons into B16's and B17's.
autowrench07
Jul 26, 2012 07:55 AM
E85B18
Mar 8, 2010 02:34 PM
turboant
Sep 28, 2005 05:39 PM
Drag-Accord
Mar 23, 2005 10:20 PM
sickerhatch
Mar 14, 2005 05:16 AM
