88 si/pcm/harness questions
Old Jun 9, 2005 | 11:14 PM
93formula's Avatar
Default 88 si/pcm/harness questions
id like to know if the 88 dx pcm will work with a 88 crx si engine harness for the mpfi conversion.
i will also be doing a vtec swap as well, can i use the 88 crx si harness or will i have to swap out the entire engine harness, if i do have to swap then i wont have to buy the 88 crx si harness right now.
so to clear things up, im swapping in the mpfi, and a jrsc and a z6 head.
should i get a 88 crx si engine harness?
should i get a 88 crx si pcm?
i know for the vtec ill need to get a differnt pcm, cant remember off the top of my head right now, so maybe i wont need the 88 crx pcm.
Old Jun 10, 2005 | 12:15 AM
Rywire's Avatar
Default Re: 88 si/pcm/harness questions (93formula)
Do a dpfi to mpfi on your dpfi harness. Its the easiest way, and the less stressfull just like what we sell at rywire
Old Jun 10, 2005 | 12:18 AM
93formula's Avatar
Default Re: 88 si/pcm/harness questions (droppedcrxsi)
ill check out your site, thanks
BigbamaBen
Dec 17, 2011 08:33 AM
VTECdohcter
Jul 9, 2010 07:57 AM
NoLeftTurn
Jan 19, 2009 04:34 PM
AllMotorMark
31
Jun 5, 2005 01:59 AM
