Going to use sawzall to cut piping, what kind of blade should I get?
Old Jun 9, 2005 | 11:14 PM
BlueShadow's Avatar
Default Going to use sawzall to cut piping, what kind of blade should I get?
Hi guys,
Tomorrow I'm gonna weld up my DP and DT. I wanna use my sawzall, since I'm not going to be doing a lot of cutting. I'll probably just make 2 cuts on some 2.5" SS pipe, and 3-4 on som 1.75" mild steel pipe.
When I look a the blades for the sawzalls how do I tell apart the blades meant for cutting wood, and the ones meant for cutting steel? I think I read on here that the blades with smaller teeth close together are good for steel. I'll also get a hacksaw as a backup in case my sawzall starts acting up, which it did the last time I used it.
anyways any help would be great
Thanks
Old Jun 10, 2005 | 03:07 PM
Ca$h's Avatar
Default Re: Going to use sawzall to cut piping, what kind of blade should I get? (BlueShadow)
I jsut go to Lowes and get the Lenox or Milwaukee Bi-Metal blades. The package is marked for Metal or Wood. I use 24tpi blades for .125 wall thickness or less. I've also used 18tpi before when I ran out of the 24's and they work fine too just a little more aggressive. I've only cut Mild steel with the sawzall though so I dont know if they'll work for SS or not. I'll look on the package tonight and let you know. The Milwaukee blades are 5 for $14.
Old Jun 10, 2005 | 06:10 PM
johnmay19's Avatar
Default Re: Going to use sawzall to cut piping, what kind of blade should I get? (KP)
Everytime I have used a sawzall to cut stainless the blades get chewed up quick. So I went to using a chop saw, much better.
Old Jun 10, 2005 | 07:36 PM
BlueShadow's Avatar
Default Re: Going to use sawzall to cut piping, what kind of blade should I get? (johnmay19)
Well, I checked out ne of my local hardware stores and the one I went to didn't have any sawzall blades. So instead I got a hacksaw instead and 4 extra blades. I thought that was going to be enough but it wasn't.
They had a pnuematic die grinder with one of those 3" fiber woven cut off disks. That worked really good. I was able to make 4 full cuts on 2.5" SS piping with one 3" disk.
Old Jun 11, 2005 | 05:55 PM
Engloid's Avatar
OG Fabricator
The sawzall will work well if you do it right. Heat makes stainless cut slower and dulls blades quickly. Therefore, having a variable speed sawzall is a good idea so that you can run the blade slower. Also, you can use a spray bottle to mist the pipe and blade while cutting it. Use a lot of water and keep it as cool as possible for best cutting and blade life. The same holds true with hole saws.
If possible, I will submerge a part in water and cut it (keeping the motor out of the water of course) and I find that it keeps the part nice and cool....making the cut faster and getting many more cuts from the same blade/hole saw.
Old Jun 11, 2005 | 09:32 PM
BlueShadow's Avatar
Default Re: Going to use sawzall to cut piping, what kind of blade should I get? (Engloid)
I used a little oil, but I dont think it would have mattered. The hacksaw would have taken too long and if my sawzall blades hadn't been dull I probably would have made a crooked cut. I thnk when I cut the piping for the rest of my exhaust I'll just use a die grinder and a few fiber woven cutoff disks.
b16bri
Welding / Fabrication
18
Mar 8, 2015 12:10 PM
BodyKits NW
21
Oct 21, 2006 10:30 PM
Superorb
16
Feb 23, 2006 06:18 PM
SRd240sx
Jan 10, 2005 12:00 AM
self_made
11
Sep 28, 2004 07:16 PM
