Suspension & Brakes Theory, alignment, spring rates....
rear sway for a crx
Old Jun 9, 2005 | 07:43 PM
jaydmcrx's Avatar
Default rear sway for a crx
Looking for a good rear sway bar for a crx. I was wondering what you guys suggest. Is the suspension techniques too stiff for a road coarse? I've heard that maybe it is. Any other suggestions, or should i be fine with a st or eibach.
Old Jun 10, 2005 | 08:27 PM
bc_ef8's Avatar
I'm using ST front and rear sway bars. Did a lapping day with them with the rear on the stiffest setting. I didn't find it too stiff, felt pretty good. Enough rotation for me but you have to be on your toes when trail braking. The rear ST sway bar has 3 settings for stiffness.
Old Jun 11, 2005 | 07:09 AM
CRX Lee's Avatar
Default Re: rear sway for a crx (jaydmcrx)
Not a lot of options for an adjustable rear bar on a CRX. The ST bar is the only adjustable one I know of and lots of people use them on road race cars. I have one but haven't used it yet and it bolts to the bottom rear shock bolt instead of directly to the lower control arm like the stock bar does. I have a non-adjustable Neupseed rear bar on the back of my daily driver that I have used on three or four street and race CRXs over the last nearly 10 years. It is a nice piece, uses spherical rod ends for end links and mounts to the lower control arm directly but it is not adjustable.
The are probably the two most common rear bars.
Old Jun 11, 2005 | 12:03 PM
jaydmcrx's Avatar
Thanks for the info guys. I am on 205-50-15 kuhmo mx's now, so i think i can get away with no rear sway for now. But i think it will be quite evident that i will need one once i get my r compounds.
Old Jun 11, 2005 | 10:10 PM
Tyson's Avatar
Default Re: rear sway for a crx (CRX Lee)
progress also has a rear adjustable sway bar that fits the CRX.
neuspeed has swaybars for the CRX as well.
addco currently lists a sway bar for the crx. havent seen a picture. they say 3/4" thick.
ST bar is fairly cheap tho. which is why its commonly used.
mugen rear bar 22mm fits like OEM. just not available anymore. i got mine used, but in great shape.
there was some other company that had a rear bar that fit like stock... cant remember. ill have to dig it up...
[edit] eibach and intrax both show civic/CRX 88-91 applications and i think they use stock mounting as well.
Modified by Tyson at 11:25 PM 6/11/2005
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
killercrx91
Jun 1, 2009 03:25 PM
CRX_Honda
27
Feb 26, 2009 11:35 AM
Ruby Civic
Aug 7, 2002 06:56 PM
