over heatin problem
I got a 92 integra and its over heating.
I have try putting 50/50 in the reservoir and 2 days later its empty. Ive gone though 2 bottles aready.
Ive tried checkin for leak but dont see any at all.
Thanks
Thanks
if it's not leaking out of the engine.. then there's a problem.
start the car up and feel the upper rad hose..
If it get's rock hard then you need a headgasket.
that's most likely the case!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS »</TD></TR><TR><TD CLASS="quote">Leaking any on the ground? Like from the freeze plugs? Any in the oil? Could be bad headgasket if there is some in the oil.</TD></TR></TABLE>
unless the headgasket is totally blown to ****, you will not find coolant in the oil by checking the dipstick. you'll find it with the head pulled off with oil in the coolant jackets
Sl0wH0nda
Jun 13, 2013 10:22 AM
dynastix9
Dec 18, 2005 06:33 AM
