Auto close sunroof if it rains
Does anyone live is a hot climate and like to crack the sunroof open during the hot summer days? Yeah, that's fine and great until it rains. Has anyone come up with a solution? Maybe just a sensor idea and I can probably figure out the controller and power supply.
There is one company that I know of that makes a rain sensor like this; it's made by Webasto and looks like this:
That piece is $200; not quite what I had in mind.
I know some cars have built-in rain senors that use the refraction change of glass when raindrops hit the surface... although these are typically used for auto wipers.
Thanks for any thoughts!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be »</TD></TR><TR><TD CLASS="quote">you can make a set-up where if you turn on your wipers your sunroof closes. </TD></TR></TABLE>
so will the sunroof close and open like it turn on/off the intermittent wipers?
Yes. Its out there. My friend has one that does that. All you need is an alarm that has relays set up to open/close what ever you want. When I had my bagged truck back in the day, if I walked more then 40 feet from my truck, the windows would roll up, alarm would set and the truck would dump itself to the ground. All you need is relays.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be »</TD></TR><TR><TD CLASS="quote">no it wont. the wipers send a signal to a timer relay that makes the wipers intermitent. but that would be hella funny.</TD></TR></TABLE>
usually its not the alarm that controls the opening/closing of windows, its usually an extra window module that you install with the alarm. all the alarm needs to have a (-)neg armed output, which most alarms should have
i am assuming he ment something that actually closes the sunroof when it starts raining, requiring no human intervention at all.
I was going to say if you could find some moisture sensor that has a high tolerence, or if you can fork over the $200 for that window mount unit thingy you put a picture of up, and could intergrate either one into the DEI 529T (IIRC), that would do the trick. The 529T is the unit that controls 1 window in either direction. You could actually apply the moister sensor setup to a setup of 530T's to control all your windows so they would all close if they were open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGPrelude »</TD></TR><TR><TD CLASS="quote">
i never mentioned anything on an alarm all i said is that you can set it up so when you turn on the wipers the sunroof can close
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">i am assuming he ment something that actually closes the sunroof when it starts raining, requiring no human intervention at all.
I was going to say if you could find some moisture sensor that has a high tolerence, or if you can fork over the $200 for that window mount unit thingy you put a picture of up, and could intergrate either one into the DEI 529T (IIRC), that would do the trick. The 529T is the unit that controls 1 window in either direction. You could actually apply the moister sensor setup to a setup of 530T's to control all your windows so they would all close if they were open.</TD></TR></TABLE>
Yeah, you've got the right idea. I'm not in the car when all of this happens. I'm already prepared to wire up a 529T.
Any leads on a rain sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa »</TD></TR><TR><TD CLASS="quote">
Any leads on a rain sensor?</TD></TR></TABLE>
The problem is you already have a solution. Design costs are expensive I doubt you could design one that is as good as the one you already found for under $200 exspecially if you weren't going into production.
There are a few ways to accomplish this. What I found is a practially "finished" product. I have a suspicion I can find the same type of device from an OEM for a lot less. Remember, their product is a ready-to-install package. I'm willing to do some hacking.
On that note, does anyone know of anyone who has one of those 130-in-one or 200-in-one electronic project kits? Maybe a cousin or little brother or someone like that...
I had one years ago... Anyways, the manual is filled with various projects (like a rain sensor, that I've seen on various websites). If someone will either point me to where I can find a .pdf version of one of those manuals or scan me a page or two. You'll be the first to know the solution to this rain sensor and I'll help you build the project.
