where do i mount this huge hid ballast?
Old Jun 9, 2005 | 02:55 PM
01nhbgsr's Avatar
Default where do i mount this huge hid ballast?
Any one with this same ballast? if so please help me. Where the heck do i mount this thing? Also i drive an 01 integra gsr if that helps.
Old Jun 9, 2005 | 03:28 PM
Racermech's Avatar
Default Re: where do i mount this huge hid ballast? (01nhbgsr)
holly crap, what did that come out of???
I would say maybe down in the bumper, but i odnt htink your lead is long enough
Old Jun 9, 2005 | 03:30 PM
97tegGS's Avatar
I would say along the fender or some flat surface that doesn't move.
I would try hooking it up first to see what you have to play with.
You might end up having to splice if nothing is availble
Old Jun 9, 2005 | 04:34 PM
01nhbgsr's Avatar
yea its quite big but does anyone have any good suggestions? I mean im willing to take the risk just to install these. someone help please~
Old Jun 9, 2005 | 05:33 PM
Naruto's Avatar
I would try to find a neat lil spot in the engine bay ( if possible ) that's out of the way of everything else....so as long as the finished install will look clean and not give too much of a "cluttered" appearance. There's also some people who will say to take the fenders off and mount those ballasts ( if possible through splicing some longer wires ) somewhere inside or above the fender well lining. Whichever way you choose....good luck
Old Jun 12, 2005 | 01:16 PM
showNgo_00's Avatar
Default Re: where do i mount this huge hid ballast? (psychoticmindset)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01nhbgsr &raquo;</TD></TR><TR><TD CLASS="quote"> Any one with this same ballast? if so please help me. Where the heck do i mount this thing? Also i drive an 01 integra gsr if that helps.
It looks like what ever that came off of, it was mounted on the back of the housing. how long is the D2S/D2R bulb holder cable/wire? it doesnt look like it is very long. did you do the HID projector retrofit yet? to tell you the truth, do the E55 HID projector retrofit with "Hella" brand ballasts, alot easier to mount and run the main D2S/D2R wire to the projector. just look up "Hella ballast" or "HID ballast", and "E55" projector on Ebay for pics. this is the set up I have on my car, a 2000 Integra.
Old Jun 13, 2005 | 08:33 PM
01nhbgsr's Avatar
Default Re: where do i mount this huge hid ballast? (showNgo_00)
yea the cable isnt that long. its about 5 inches long. Also I dont think ill be doing a retrofit,i already have the bulb and everything. All i need is some advice on where and how i whould mount this.
Old Jun 13, 2005 | 11:26 PM
calxtreme's Avatar
either stick it on the bumper or inside the fender. I think you're gonna have to splice and lengthen the ballast to bulb wires. Make sure to use heavy guage wires that can support the high voltage.
Old Jun 14, 2005 | 06:16 AM
juicy.fn's Avatar
be creative! my ballast is WAY bigger than that and i found some spots to place them. one is under the abs and the other is zip tied by the headlight. youll find a place for it trust me
Old Jun 14, 2005 | 10:28 PM
01nhbgsr's Avatar
Default Re: (juicyfn)
haha damm. yea ill give it some trys, and when i figure it out ill post up pics and how and where i installed it. thanks guys
Old Jun 15, 2005 | 06:11 AM
juicy.fn's Avatar
Default Re: (01nhbgsr)
yeah please update us, retrofiting is becoming more popular. this way people can see where you mounted the ballasts
Old Jun 15, 2005 | 06:27 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by showNgo_00 &raquo;</TD></TR><TR><TD CLASS="quote">
It looks like what ever that came off of, it was mounted on the back of the housing. how long is the D2S/D2R bulb holder cable/wire? it doesnt look like it is very long. did you do the HID projector retrofit yet? to tell you the truth, do the E55 HID projector retrofit with "Hella" brand ballasts, alot easier to mount and run the main D2S/D2R wire to the projector. just look up "Hella ballast" or "HID ballast", and "E55" projector on Ebay for pics. this is the set up I have on my car, a 2000 Integra.</TD></TR></TABLE>
the e55 projectors are just "okay"
cutoff isnt that sharp compared to others and beam spread (width) isn't up to par with alot of other projectors.
Look into a tsx, s2k, something along those lines.
Old Jun 15, 2005 | 07:01 AM
Shaun's Avatar
as the guy said above, zip ties may work.. I also wrapped my ballast in electrical tape so water doesnt destroy them
Old Jun 15, 2005 | 09:49 AM
95gsrteg's Avatar
Default Re: (Shaun)
just curious, but what car is that ballast/hid system from? i've never seen one like that.
Old Jun 15, 2005 | 03:58 PM
01nhbgsr's Avatar
Default Re: (95gsrteg)
this hid ballast came off a euro accord type R
Old Jun 15, 2005 | 04:37 PM
dragoncoach's Avatar
Don't rig it! I don't know how large it is exactly, but there is some room next to the ABS in the right front of the engine compartment. I installed my air horn compressor there. I would have to look at it to give you some ideas. You just have to be creative and innovative. You'd be surprised at the ideas you can come up with. If you are in SF, pm me and I can look at it and maybe give you an idea.
Old Jun 15, 2005 | 07:30 PM
ernald711's Avatar
Default Re: where do i mount this huge hid ballast? (Racermech)
fender
Old Jun 16, 2005 | 02:54 AM
juicy.fn's Avatar
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">as the guy said above, zip ties may work.. I also wrapped my ballast in electrical tape so water doesnt destroy them </TD></TR></TABLE>
i wrapped my ballasts with old inner tube from a tire, this keeps it from getting wet
Old Jun 16, 2005 | 06:13 AM
juicy.fn's Avatar
Default Re: where do i mount this huge hid ballast? (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">fender</TD></TR></TABLE>
cant do the fender, like my ballasts, the cable isnt long enought to place it anywhere in the fenders
Old Jun 16, 2005 | 11:29 AM
JDM.Jay's Avatar
mount it to any flat surface, near the fender or behind the headlamp if you have room
parmo
Honda Civic (2001 - 2005)
Oct 24, 2007 02:10 PM
vthree
May 4, 2006 09:52 PM
MaskedAP1
Nov 10, 2004 12:17 PM
enrique
May 29, 2003 09:59 PM
gsr-2nr
Mar 26, 2003 06:09 AM
