motor assembly in general...
Hey guys...I have a few basic 4-cyl motor assembly questions.
1) Cleaning the head---is it ok to clean the head using Varsol and cleaning the valve seals using the same product?
2) when assembling a head with the valvetrain, what do I need to lubricate and grease up?
Thanks
bart
Thanks
bart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">assembly lube for valvetrain.</TD></TR></TABLE>
Lots Of It!
Also using varsol will not hurt the head, although i would be hesitant to get it around the seals...
Lots Of It!Also using varsol will not hurt the head, although i would be hesitant to get it around the seals...
Well I know I need assembly lube for the valvetrain...but what specifically?
disregarding the camshafts because I know how to prepare them but what abotu the valves/springs/retainers/etc... what do I grease/lube up within that selection?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">
disregarding the camshafts because I know how to prepare them but what abotu the valves/springs/retainers/etc... what do I grease/lube up within that selection?</TD></TR></TABLE>
You may want to throw some oil inbetween the seat and the head to insure a good "oil seal" yet other than that, Just check the installed height, rocker arm to retainer clearance. Seal to guide clearance etc..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR »</TD></TR><TR><TD CLASS="quote">
You may want to throw some oil inbetween the seat and the head to insure a good "oil seal" yet other than that, Just check the installed height, rocker arm to retainer clearance. Seal to guide clearance etc..</TD></TR></TABLE>
Thanks man...now here is the blow away...this info is for me rebuilding my friends toyota paseo motor
basically this helped because all i wanted to know is where to lube/grease up the valvetrain
HondaCivicSiR1
Mid-Atlantic (Sales)
22
Mar 18, 2008 08:22 AM
AllMoToRB18c
Jun 24, 2007 06:53 PM
