FS: Radiator, Shifter, P75, Computer Parts, DVDs, More (SC)
Every item you see for sale in this post is “or best offer.” If you do not agree with my asking price, simply come at me with your offer for the item. I am also willing to work with local buys to drop items off and drop the price some to compensate for the lack of shipping. If you are interested in multiple items send me an offer for them as bulk, and include shipping in your price if the items will need to be shipped. If you would like more information on any item, different photos, make an offer, or inquire about an item in general please post in this thread, send me a PM or contact me via one of the methods given below. My information is below as well.
Contact: Jason.Bruce at tmitbyh dot com
AIM: tmitbyh
[color:"red"] Automotive Related Items [/color]
1997 Acura Integra LS P75 ECU - $75.00 Shipped
I purchased this from a junk yard in Arkansas and decided to go OBD-I with my swap. I still have the receipt from the junk yard that I can include if you are interested. I have not altered this ECU nor tested it. The junk yard said it had been tested by them and was good.
Auto Meter Pro Shift Lite - $50.00 Shipped
I never installed this item and it was purchased used. It worked when the seller sold it to me according to them. I have no need for it.
2002-2003 Nissan Sentra SE-R SPEC V Motor Mount Inserts - $35.00 Shipped
These are brand new and never been installed or used.
SR20DE Oil Pan - $35.00 Shipped
This was purchased for the G20 I had with a bent oil pan. I ended up getting rid of the car before I put this oil pan on and now have no need for it.
[color:"red"] Computer Related Items [/color]
3.5" Floppy Drive - $3.00 Shipped
I simply have no need for it any more.
Quantum Fireball Hard drive - $5.00 Shipped
It is a five gigabyte hard drive. I was using as my swap file drive for a while and no longer need it.
Artec CD-RW WRR-4048 - $15.00 Shipped
I upgraded to a DVD burner and have no use for this burner any more. It was operational when I upgraded. Features and specs are as follows;
-Plug and Play, easy to install and use - fits any ATAPI/E-IDE interface connection.
-MPEG compact disc applicable
-Built-in intelligent power saving function
-Supported under Windows 95, 98, ME, NT, 2000 and XP
-Maximum 6000KB/sec data transfer rate for recording and 1800KB/sec for rewriting
-Compatible with the CD-RW standards including CD-DA, CD-ROM/XA, CD-I, Mixed Mode and Video CD
-Plug and play
-Reading Speed: 48x (CAV), 7200 KB/s (Max)
-Recording Speed: CD-R / 40X (CAV), CD-RW / 12x (CLV)
-Average Access Time: 100ms (1/3 stroke avg.)
-Data Buffer Size: 2MB
-Reading Mode Formats: CD-DA audio, CD-ROM, Multisession / Multi Volume - CD-ROM XA or CD-I, MultiMedia - CD-ROM / XA or CD-I (Compressed Audio, Video, graphics, Tracks 2-99) UDF, BOOTABLE
-Recording Mode Formats: Track at once, Disc at once, Incremental packet writing and reading, Multisession Data, (Direct) overwrite on CD-Rewritable discs in all modes according Orange Book Part III Min, JustLink supported
-Interface: E-IDE (ATAPI)
Samsung SM304 DVD/CDRW Combo Drive - $10.00 Shipped
I was using this drive before I purchased the Artec one. It was operational when I upgraded. Features and specs are as follows;
Speed: 4X/4X/24X CD-RW Drive + 4X DVD-ROM
-Data Transfer Rate Read CD: 3,600 KB/sec (24X)
-Data Transfer Rate Read DVD: 5,400 KB/sec (4X)
-Data Transfer Rate Write on CD Record: 600 KB/sec (4X)
-Data Transfer Rate Rewrite: 600 KB/sec (4X)
-Burst Transfer Rate: PIO Mode 4 (16.6 MB/sec), DMA Mode 2 (16.6 MB/sec),Ultra DMA(option)
-Average Access Time DVD: 120 ms
-Average Access Time CD: 110 ms
-Supported Disc: DVD-ROM,DVD-Video, CD-ROM,CD-R,CD-RW, CD-DA,CD-ROM/XA, Video-CD,CD-I/FMV, Multisession Photo CD, Enhanced CD,CD-Extra
Toshiba PCX DOCSIS 1100U Cable Modem - $20.00 Shipped
I used this modem the two and a half years I lived in Georgia and then moved to Iceland where I was on dial-up and DSL. I used it for a few months when I moved to South Carolina and then purchased a new Cisco one to match my routers and other equipment. Everything is in excellent condition and still works.
Belkin Four Port USB Hub - $5.00 Shipped
I have no need for it anymore as my new motherboard has more than enough USB ports for all of the devices I have. I do not have the AC adapter for it anymore however but it still work fine as it can be powered by the USB port.
Lynksys Ethernet Card - $5.00 Shipped
I was using this in my machine before I upgraded and went with a motherboard with an onboard NIC. It worked fine when I pulled it out of the machine and has been in a static bag since.
ATI Radeon VE (dual monitor) - $40.00 Shipped
I used this video card for a few months before I outgrew it as I started to get into higher end games. If you are looking for a basic dual monitor set up this is a perfect card for it. When I pulled it from my machine it went into a static bag and into the box my new card came in and has been there since.
Generic 56K Modem - $5.00 Shipped
I used it during my time in Iceland while I was on dial-up before DSL was offered. I removed it after I moved to South Carolina and has been in a static bag since.
EPoX EP-8K7A Motherboard - $30.00 Shipped
I used this motherboard for about a year and then upgraded everything in my machine. Once it was removed it went back into the static bag and in the box it came in.
Chip Sets
This motherboard uses the AMD-761 & VIA 686B AGP set.
EIDE
The EPoX EP-8K7A has Ultra DMA-100 EIDE Controllers and backwards compatible with PIO mode 3/4 & Ultra DMA-33/66. It has two EIDE connections each one will support 2 devices giving you a total of 4 EIDE devices.
Memory
There are two memory slots made for the DDR memory, each slot can hold up to 512MB of PC1600 or PC2100 DDR RAM, for a total of 1024MB of memory.
I/O Controller
The motherboard supports 1 Floppy drive controller, 1 Parallel port (EPP, ECP) and 2 Serial ports.
Other Ports
There are two onboard USB ports and two more USB ports if you purchase a cable giving you 4 USB ports from the motherboard.
There are also two PS/2 connections, one for a mouse and the other for a keyboard.
Slots
There are No ISA slots just, six PCI 32-bit slots and one AGP slot that supports modes 1x, 2x and 4x.
Audio
The motherboard has a built-in AC97 Digital Audio.
The built-in sound card has Sound Blaster Pro compatibility.
Supports
The EPoX EP-8K7A motherboard supports CPU Vcore & Vio setting with jumpers, plus CPU multiplier and clock through the BIOS options.
Extra Functions
KBPO (Keyboard Power On) Use the keyboard to power on the system.
USDM (Unified System Diagnostic Manager) In Windows it lets you monitor things like system temperature and more.
VT82C686B chipset is for monitoring hardware functions.
P80P Debug (POST) Card onboard with an LED display.
Over Clocking
The EPoX EP-8K7A gives you the opportunity to over clock which some boards do not offer.
Evercool Water Cooler WC-201 - $75.00 Shipped
I purchased this kit new and ran it for about a week when my new case arrived and found it would not fit. I removed it from my old case and placed everything back in the box and have not touched it since. One of the primary features of this kit is that part of it mounts within a CD ROM slot. The kit includes:
-CPU and GPU waterblocks with P4, AMD K7/K8 mounts
-External radiator and fan
-Tubing (¼" ID) with screw-on mounts
-Thermistor cable
-Assorted screws, washers, thermal grease, tubing tool
-Anti-freeze
Note that in addition to the CD ROM size unit, there is a second radiator which mounts in an 80mm fan cutout.
[color:"red"] Electronics Related Items [/color]
South Park Volume 1-4 - $5.00 Shipped each or $15.00 Shipped for all
These came out long before they released the complete seasons. I started to get the full seasons and have no use for these any more.
Volume 1: “Cartman Gets an **** Probe,” “Volcano,” “Weight Gain 4000,” “Big Gay Al’s Big Gay Boat Ride.”
Volume 2: “An Elephant Makes Love to a Pig,” “Death,” “Pinkeye,” “Damien.”
Volume 3: “Starvin’ Marvin,” Mecha Streisand,” “Mr. Hankey, The Christmas Poo,” “Toms Rhinoplasty.”
Volume 4: “Cartman’s Mom is a Dirty ****,” “Cartman’s Mom is Still a Dirty ****,” “ Chicken Lover,” “Ike’s Wee Wee.”
Modified by tmitbyh at 10:33 PM 6/22/2005
AIM: tmitbyh
-Plug and play
Chip Sets
EIDE
Memory
I/O Controller
Other Ports
Slots
Audio
Supports
Extra Functions
Over Clocking
-Thermistor cable
-Anti-freeze
1994-2001 Integra Radiator, Playstation 2 auto modellista, & Pioneer S-P2500 Bookshelf Speakers have been sold.
VTECisSeXY you have a message waiting for you with all of my information.
I also have a '92 Integra GS that I am parting out if anyone needs parts from it let me know.
-JB
-JB
Mr. KDes
Northeast (Sales)
54
Apr 19, 2011 11:12 AM
