bad news!!!
today while i was driving my timing belt broke
and it bent my valves so i need to get the head redone or buy a new one...i was thinkin of buyin a b16 or gsr head...anyone have any opinions??
LS/Vtec is more than just the head.
I say rebuild the head you have, put some nice cams in with a good valve train. Port and polish the head, match port the intake and TB and you will be fine.
well what are your plans with the car? does smog bother you? Do you have anyother modes of transportation? gotta let us know these things for informed opinions.
personally id go b20, then down you road put on a vattack head.
well i should be ok on the transportation tip...its just that i dunno...how much **** would i need to do an ls/vtech head...or i was thinkin bout a type r...i can get a whole b18 for like 400
If you have the time, and the money do get it done RIGHT... go for the lsvtec, but don't expect anything amazing out of it stock. It will, however, feel awesome compared to your ls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenzoDaPlayboi »</TD></TR><TR><TD CLASS="quote">today while i was driving my timing belt broke
and it bent my valves...</TD></TR></TABLE>
Bad news indeed.
and it bent my valves...</TD></TR></TABLE>Bad news indeed.
build the LS!!!!!!
Can ya tell i drive an LS
Anyways the LS Vtec takes quite a bit of time and mooney to do it right. Search will be your best friend to do it right. You will need the head and everything attached to it(i am 99%sure you current header will be fine) the golden eagle oil kit. Either a Vtec controler or a Vtec ECU(am i correct on the ecu part?) Timing belt water pump, maybe the oil pump.....etc the list goes on and on. I looked into doing it for a while but now i am gonna run my LS till she blows then it is onto a full GSR motor
same thing happend to me in my ls luckly i had an extra ls head which was off a blown block motor i say rebuild it doesnt cost that much money.. all machine shop work should be around 150-200
yo i had just checked the belt like last week...this **** was so new looking...there was no wear or tear on it...then all of a sudden im coming off a stop sign and bang...my **** just shuts off while i was driving...i dunno what happened man...i am hearing it is hard to take off the head...and that i will have to do mad **** if i want to put a vtech head on...
If your on the cheap, go to your local auto parts store and buy a cheapy Haynes or Chiltons manual for like $12. It will give you a step by step on removing your head, then take it down to your local machine shop. Have them check the valves and replace any bent ones. While your head is off, take a look at the top of your pistons, make sure they look ok. Then pick up your head and reinstall. That easy man. If you had a few bucks, you could have them do a 3 angle valve job and install some aftermarket valvesprings. Then in the future if you want to upgrade your cams, you will be all set.
I just did the LS/Vtec conversion cause the same thing happened to me....driving along minding my business when the belt snapped and bent my valves. I got everything done including ALL the parts for around 2500. I replaced/bought the following:
GSR head
water pump
timing belt
head rebuild kit (it was a used head and I didn't wanna take the chance)
Block guard
Vtec Dizzy
Z10 Vtec conversion kit
Throttle cable (that I had to mod anyway)
intake gasket
exhaust gasket
Short Ram intake
GSR intake
VAFC2
P28 (chipped)
OBD2a-OB1 conversion harness
I'm probably forgetting a couple things, but you get the idea. Do I like it....hell yeah. Would I have done it differently...probably would have also done the whole bottom end if I had to do it over again. It pulls a little harder and climbs a lot faster in the RPM's when VTEC hits. My gas mileage went down a lil bit (like 80 less per tank or so)
GSR head
water pump
timing belt
Block guard
Vtec Dizzy
intake gasket
exhaust gasket
Short Ram intake
GSR intake
VAFC2
P28 (chipped)
If you think you'll spend upwards of $2000 on an ls/vtec conversion, I'd say that's not money well spent. For less than that you could have a GSR long block from hmotorsonline and have a good solid motor to build upon without all the conversion complications and machine work that'll need to be done. Ls/vtec will never be as reliable as OEM Honda...but I guess it depends on how important longevity is to you. Just my $.02.
