banlancer oil seal retaining plate
Old Jun 9, 2005 | 10:43 AM
accordredliner's Avatar
* B A N N E D *
Default banlancer oil seal retaining plate
does the 97 accord have one already intalled?
Old Jun 9, 2005 | 11:11 AM
deserthonda's Avatar
i don't think so ....i beleive there was a recall on 94-97 accords you might want to ask dealer because if your car does not have it they should install for free
Old Jun 9, 2005 | 01:26 PM
Chiovnidca's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">i don't think so ....i beleive there was a recall on 94-97 accords you might want to ask dealer because if your car does not have it they should install for free</TD></TR></TABLE>
That expired a couple years ago. Good luck getting them to goodwill one.
Old Jun 9, 2005 | 01:44 PM
Turbowa's Avatar
Default Re: (Chiovnidca)
Was there a re-call, YES. Is there any more, NO. And the dealer will not good will it. If your having your timing belt done this can be put on for no labor and the part is only like $3-$5 depending on your location. If its not on there now you should really get it put on. Even if your not having a timing belt replaced its not that much to have the retaining plate put on. You really don't have to remove the timing belt cover to install one.
Old Jun 9, 2005 | 04:45 PM
YeuEmMaiMai's Avatar
IF you have had your timing belt replced any time since the recall started, they should have installed the oil shaft retainer at the time they installed the timing belt. I had my belt replaced in 2K1 and it was installed at that time.
Old Jun 10, 2005 | 03:14 AM
ricebike's Avatar
http://www.cybertrails.com/~be....html
i was surfing on this guy's site about gathering parts for wifey's t-belt job... & have to check if that plate is on there as well.
aptyk88
14
Jul 15, 2008 09:04 AM
watsoran
Dec 11, 2005 01:25 PM
04accord94civic
May 1, 2005 07:25 PM
david90
Jul 5, 2004 07:19 AM
jdm4life
Oct 23, 2003 01:40 PM
