missing a bracket for my e-brake cable?!?!?!?!? ahhhhh
i got a type r brake swap off a ctr for 600 bucks from a shop in MA but little did i kno it was 600 for a reason. it came with alot of missing stuff, a siezed up bolt on it, and cracked rotors
but i got it on now.
when i rotated the tires on my dad's accord i notice there is a bracket that holds the ebrake cable near the rear calipers. It has those metal clips that shape like a big U that clips on to the e brake cables and holds it on to the bracket. i realized i never had those on my brake swap and i tried to look for it on http://acuraautomotiveparts.org but i cant seem to find it.
i found the metal clip for it but not the bracket.
dose anyone kno what its listed under on that site?
i'll take a pic later to try and explain what im missing after work.
but i got it on now. when i rotated the tires on my dad's accord i notice there is a bracket that holds the ebrake cable near the rear calipers. It has those metal clips that shape like a big U that clips on to the e brake cables and holds it on to the bracket. i realized i never had those on my brake swap and i tried to look for it on http://acuraautomotiveparts.org but i cant seem to find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Big ole ziptie... if its the bracket that I think. It just holds the ebrake line to the trailing arm right?</TD></TR></TABLE>
give it time and the ziptie will eat through the ebrake line/fray it.
i wonder if the itr bracket will work ...
yea i dont want to half *** it. i dont like to do things that way
anyways heres some pics to explain my situation.
the 2 holes down there have threads so i kno there a bracket that bolts up to it it looks just like the brake lines where you use those flat clips and press them in to hold it down. lookin at my dad's accord he has that i dont..
nadda problem. I knew because I had a little trouble making the ones from my LS cables fit onto the rear prelude calipers when I was finishing up the 5 lug conversion....
CBL9
Jul 26, 2007 05:51 PM
JohnS_93
Dec 18, 2006 03:12 AM
