cat question
Old Jun 9, 2005 | 08:04 AM
tech0937's Avatar
Default cat question
have JDM type r motor in car and have Original LS Apexi N1 full cat back on car. Going to buy a type r cat from someone on h-t but was not sure if this is a direct bolt on. the JDM header has a 2.5'' collector. does anyone kow if this will fit? any help is much appreciated.
Old Jun 9, 2005 | 08:06 AM
BlueR's Avatar
Default Re: cat question (tech0937)
USDM cats will not fit with JDM headers
Old Jun 9, 2005 | 08:14 AM
RTW DC2R's Avatar
JASMA makes JDM
Old Jun 9, 2005 | 08:41 AM
Chris F's Avatar
Default Re: (RTW)
<FONT COLOR="blue"><FONT SIZE="10">JASMA CAT doesn't think that's funny.</FONT></FONT>
Old Jun 9, 2005 | 08:43 AM
Nishant's Avatar
Default Re: (Chris F)
bahaha
Old Jun 9, 2005 | 10:23 AM
citrus3000psi's Avatar
Buy a 2.5 carsound cat...
Old Jun 9, 2005 | 10:37 AM
tnord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="blue"><FONT SIZE="10">JASMA CAT doesn't think that's funny.</FONT></FONT>
this whole jasma thing has officially gone too far.
Old Jun 9, 2005 | 10:42 AM
Nishant's Avatar
Default Re: (tnord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">
this whole jasma thing has officially gone too far. </TD></TR></TABLE>
starting to get old IMO
Old Jun 9, 2005 | 10:47 AM
Ill's Avatar
Ill
What header do you have? (JDM 2.5 header is not only larger diameter, it's longer, meaning you need a shorter cat). USDM cat is 2.25" dia. Do you have the header on the car right now?
Carsound is a good, inexpensive option. You may also be able to find a used JDM cat.
You mention having and 'LS' exhaust. Is that the model name, or was it for an LS originally? If so, it is the right length to bolt up, but I'm not sure about the diameter. Can you measure the B-pipe dia?
You also want to ditch the stock 'ring' gasket (if not already), and put a 3-1/2 bolt circle, 3 bolt, 2.5" flat gasket between the cat and the b-pipe.
Old Jun 9, 2005 | 04:38 PM
tech0937's Avatar
yes it was originallyfor an integra LS but the header is a jdm header with a 2.5'' collector. will the stck JDM cat bolt right up? and where can i get the gaskets you're talking about?
Old Jun 9, 2005 | 05:09 PM
B2FiNiTY's Avatar
Default Re: (tech0937)
The cat will bolt up to the header but will be too short for the catback. You will need a jdm length catback or extend the b-pipe in order to bolt up the jdm cat. Or, just get a custom carsound cat.
planetstereo
Sep 21, 2005 06:53 PM
euG3dc2r
Oct 7, 2004 10:14 AM
ChopstiX
Oct 29, 2003 09:23 AM
APEX i GSR
Jul 17, 2003 07:03 PM
EvoTypeR
Apr 10, 2002 05:35 AM
