1.8 Swap questions
91 Crx... d16 1.6 SOHC
What i want to do is take a 92 integra GS. b18a1 DOHC and swap engines.
Now i found a good place for the engine and tranny and ECU.
I'm just wondering about the motor mounts...
They different? I'm up in Toronto so Hopefully anyone can give me some advice on to the best place to pick up motor mounts.
Another thing. Exhaust headers. if i get them for the 1.8, They have enough clearance in the crx body?
Just any help would be appreicated
I am not just posting this to be an *** but try "search" to get more info.
Type "B18A in CRX" etc. in and don't forget to search the archived.
I hate this when people do it to me but it does help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedA6 »</TD></TR><TR><TD CLASS="quote">I am not just posting this to be an *** but try "search" to get more info.
Yes,yes, search is good.
Mounts are different, you will need a mount kit. Hasport comes to mind, I have them. AFAIK, all the stock B18 headers will clear the chassis, front crossmember etc. Most 4-2-1's should clear, the jdm 4-1 does not clear.
HTH
chris
</TD></TR></TABLE>Yes,yes, search is good.
HTH
chris
You will also need a new shifter linkage and depending on what civic/crx you have, you might have to change your knuckles. You will need different axles as well.
Mount kit u will need
